| Описание файла: | сервисные режимы телевизоров_4- сервисные режимы телевизоров_4.djvu
- AIWA..............................TV-C202............................................. 19
DAEWOO.......................DTC-29Z9
DTY-29Z9
DTY-29Z9PIP................................ CM-915..............................22
DAEWOO.......................DTW-2810F
DTW-28W2F.................................... WP-811..................28
DAEWOO .................... DTC-25G1TM, DTC-25G1VM,
DTC-25G3VMR. DTC-25G4VMS, DTC-25G7VM, DTC-29G1TM,
DTC-29G1VM.................................... CM-900............................. 31
FERGUSON................................... ICC11..................................................35
G RUN DIG......................DAVIDO 55
Greenville 560SE 5587TOP ST55-855TOP
ST 55-870FR/TOP................................. CUC 2021 (CUC2021F).....................44
HITACHI.........................CL2892TAN CP2892TAN...... .................. ................50
JVC.................................AV-21SX1EK, AV-21TS1EK,
AV-21TS1EN, AV-25SX1EK.......................................... 88.........................56
LG...................................CI-21Q20, CK-21Q20, CL-21Q20.............. 99DA...............65
LG..........CF-29H30. CF-29H70, CF-29K40........ MC-74A.... 72LOEWE....
..CONTUR 1263, CONTUR 1270,
MONACO 7700, PROFIL 2163,
PROFIL2170................................................................. E3000..... 76
MATSUI.......................... 1408R(T)...........81
MITSUBISHI..................C25C7B, C25D7B, C25D7L,
C25S7B, C25S7L, C28D7B,
C28D7L, C28S7B, C28S7L........................................... EE6...............87
Panasonic.....................TC-25GV10R, TC-29GV10R.............M17V...................94
PHILIPS.........................25PT5301, 29PT5301, 29PT5301 ........ GR2.4 (SUP)........... 106
PHILIPS.........................21PT441, 21PT442, 24PW6301,
24PW6321, 25PT4411, 25PT4421,
25PT4511, 25PT4512, 28PT4301............................MD1.1E.............. 110
PHILIPS.........................21PT4303/02, 21PT440B/00B,
21PT440B/58B, 21PT441B/02B,
21PT4422/01, 21PT442B/01, 21PT442B/01B, 21PT442B/05B, 21PT442B/07B, 21PT442B/16B, 21PT442B/BB, 24PW6302/00, 24PW6322/01, 24PW6322/16, 25PT45/3/02, 25PT4503/00, 25PT4503/15, 25PT4503/58, 25PT4503/58P, 25PT4523/01, 25PT4523/05, 25PT4523/07, 25PT4523/13, 25PT4523/16, 25PT4523/58, 25PT5302/58, 25PT5322/58, 25PT5403/00, 25PT5423/16, 25PT6322/05, 28PT4503/43, 28PT4503/58, 28PT4503/58P, 28PT4513/02, 28PT4523/01, 28PT4523/05, 28PT4523/13, 28PT4523/16, 28PT4523/58, 28PT5001/02B, 29PT9113 (I версия), 32PW6302/00, 32PW6312/00, 32PW6322/01, 32PW6322/13, 32PW6322/16,
32PW6332/01, 32PW6332/16.................................MD1.2E/AA................................. 117
SAMSUNG.....................CS29A5MT8X, CS29A5PF8C.
CS29A6MT8X, CS29A6PF8X, CS29A6WT8X, CS29A7HPBX,
CS29A7PTBX8........................................................ KS3A(P).......................................124
SANYO...........................CEP2570D
CEP2870D.............................................................EDO (2031)................................. 131SANYO...........................CE28WN3
CE32WN3..............................................................EB5-W.........................................136
i
SHARP...........................66DW-18H
76DW-18H............................................................. CW-100....................................... 146
SONY.............................KP-S4111K
KP-S4112U
KP-S4113..............................................................AP-1E......................................... 150
SONY.............................KV-K21MF1, KV-K25MF1,
KV-K25SN21, KV-K29CF1,
KV-K29MF1, KV-K29SN21 ...................................... G3F............................................ 158
ТА TUNG........................T25N440
T28N440
T32W440 ............................................................... 440 ............................................. 166
THOMSON.....................28DH78K, 28WS43E,
28WS78KE, 29DL40E, 29DU70E, 32VT75ED, 32WS43E, 33MS40E, 37WS88ME, 46RH40E,
52RH40E...............................................................ICC 19......................................... 170
TOSHIBA.......................28ZD06B, 32ZD06B,
32ZD08B, 32ZD08G..............................................COOS.......................................... 180
TOSHIBA.......................2152DB, 2552DB, 2555DB,
2852DB, 2855DB...................................................C5S............................................ 187
