Серега777 ЛАМЕР-ФЛУДЕРАСТ Сообщения: 133
Видеорегистратор не грузится при подключении монитора на экране тестовый сигнал цветные полосы. БП в норме , 1,8в 3,3в 12в 5в - присутствуют без пульсаций.
Процессор HI3520
Флэш 25Q64FVF
Наклейка на плате 08HL/2G
Модель майна TS80A-3520D-FLK V3.0
U-Boot 2010.06-svn133 (Jun 11 2014 - 14:34:14)
Check spi flash controller v350... Found
Spi(cs1) ID: 0xEF 0x40 0x17 0x00 0x00 0x00
Spi(cs1): Block:64KB Chip:8MB Name:"W25Q64FV"
envcrc 0x879ea08e
ENV_SIZE = 0xfffc
In: serial
Out: serial
Err: serial
Press CTRL-C to abort autoboot in 0 seconds8192 KiB hi_sfc at 0:0 is now current device
srcAddr 0x82000000, dstAddr 0x82000000
find_squashfs_file: name bin, start_block 0, offset 1284, type 1
find_squashfs_file: name boot, start_block 0, offset 1376, type 1
read inode: name boot, sb 0, of 1376, type 1
find_squashfs_file: name zImage.img, start_block 0, offset 1316, type 2
read inode: name zImage.img, sb 0, of 1316, type 2
### FS load complete: 1613452 bytes loaded to 0x82000000
## Booting kernel from Legacy Image at 82000000 ...
Image Name: linux
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1613388 Bytes = 1.5 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel. |
hisilicon # printenv
bootcmd=lload;sf probe 0;sf read 82000000 30000 400000;squashfsload 82000000;bootm 0x82000000
bootdelay=1
baudrate=115200
ipaddr=192.168.1.10
serverip=192.168.1.1
netmask=255.255.255.0
bootfile="uImage"
da=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 u-boot.bin.img;sf probe 0;flwrite
du=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 user-x.cramfs.img;sf probe 0;flwrite
dr=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 romfs-x.cramfs.img;sf probe 0;flwrite
dw=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 web-x.cramfs.img;sf probe 0;flwrite
dl=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 logo-x.cramfs.img;sf probe 0;flwrite
dc=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 custom-x.cramfs.img;sf probe 0;flwrite
up=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 update.img;sf probe 0;flwrite
tk=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 zImage.img; bootm 0x82000000
dd=mw.b 0x82000000 ff 0x1000000;tftp 0x82000000 mtd-x.jffs2.img;sf probe 0;flwrite
ethaddr=00:0b:3f:00:00:01
ID=000000000000000000
restore=0
appVideoStandard=PAL
appSystemLanguage=Russian
bootargs=mem=84M console=ttyAMA0,115200 root=1f01 rootfstype=squashfs mtdparts=hi_sfc:192K(boot),1984K(romfs),3776K(usr),1664K(custom),64K(logo),512K(mtd)
dh_keyboard=1
appauto=1
stdin=serial
stdout=serial
stderr=serial
verify=n
ver=U-Boot 2010.06-svn133 (Jun 11 2014 - 14:34:14)
Environment size: 1335/65532 bytes
hisilicon # |
Alexa.Rim Гость 31.43.*.*
Серега777, ты бы фотку майнборда прикрутил, может клон найдется какой. |
Считал прошивку флэшки 25Q64 включил сброс на заводские настройки (выставив 1 вместо 0 ) записал обратно, регистратор завелся. |
v.2012p Новичок Сообщения: 27
Серега777--- укажи подробнее---где, в каком ряду, в каком месте ты изменил в прошивке 0 на 1
для сброса на заводские (если можно---прикрепи снимок этой части прошивки) |
M - 16. Участник Сообщения: 263
Надо полагать, выставил в загрузчике restore=1 |
| M - 16. писал: | | Надо полагать, выставил в загрузчике restore=1 |
Совершенно верно, осталось проблему с ЖД решить - не видит, нет изображения с камер |
