[ Тема закрыта ] W300 Please wait
Список форумов » Сотовые телефоны » Sony Ericsson
prizrak_volk
04-12-2007 10:18
Изначально был белый экран. После прошивки висит на надписи Please waite и уже неделю так висит. вот лог прошивки
ChipID:8040,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:49
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:35647601099229 CERT:RED
PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
Flash ID check:897E
Flash props sent ok
DETACH CABLE FROM PHONE.
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Speed:921600
Trying to launch embedded bootloader...
Embedded flashloader:
COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
Flash ID check:897E
Flash props sent ok
FOUND: R9A036_CXC1123260_GENERIC_JE
Restore from:R9A036_CXC1123260_GENERIC_JE
CSloader version:
SETOOL2 LITE COMPACT_SEMC_FS_LOADER (FAT V26)
loader startup: executed
loader GDFS startup: executed
Will write GDFS now.
will write 1054 variables
unit 1/3CA write fail, err: 11
cut length from 2035(03/1389)
unit 3/1389 write fail, err: 11
done
Phone detached
Elapsed:167 secs.
Speed:921600
Flash ID check:897E
Flash props sent ok
THEN PRESS "READY"
Speed:921600
Flash ID check:897E
Flash props sent ok
writing C:\Documents and Settings\Дьявол\Рабочий стол\Работа\sony ericsson\прошивка\w300\W300i_R9A036_MAIN_GENERIC_JE_RED49\W300i_R9A036_MAIN_GENERIC_JE_RED49.mbn
CURRENT FLASH FILE CID:49
SSW uses dynamic hash, dynamic hash len is:336
Will flash 336 blocks...
SSW loading returns:0
writing C:\Documents and Settings\Дьявол\Рабочий стол\Работа\sony ericsson\прошивка\w300\W300i_R9A036_FS_RUSSIA_RED49\W300i_R9A036_FS_RUSSIA_RED49.fbn
SSW uses dynamic hash, dynamic hash len is:153
Will flash 153 blocks...
Elapsed:299 secs.
FILE RECOGNIZED AS CUSTOMIZATION PACKAGE.
CDA:CDA102665/8
MODEL:Jing Generic
VARIANT:RUSSIA
LANGUAGE: EN
LANGUAGE: RU
Speed:921600
Flash ID check:897E
Flash props sent ok
THEN PRESS "READY"
Speed:921600
Flash ID check:897E
Flash props sent ok
CSloader version:
loader filesystem startup: executed
Writing package...
Directory: tpa/preset/custom/
CONTENT_DOWNLOAD_HOOK.itm (2048)
Customize.xml (2645)
FM_PICTURES_HOOK_3.itm (10240)
FM_SOUNDS_HOOK_3.itm (10240)
FM_THEMES_HOOK_3.itm (10240)
FM_VIDEOS_HOOK_3.itm (10240)
GAMES_HOOK_3.itm (10240)
SETT_RINGTONE_HOOK_3.itm (10240)
Phone detached
Elapsed:183 secs.
Speed:921600
Flash ID check:897E
Flash props sent ok
THEN PRESS "READY"
Speed:921600
Flash ID check:897E
Flash props sent ok
Restore from:C:\Documents and Settings\Дьявол\Рабочий стол\Работа\sony ericsson\sefp010051_CID49\REST\rest_W300_R9A036.bin
Elapsed:53 secs.
Vad
Мобильщик
Мобильщик
04-12-2007 12:14
prizrak_volk, Галочку Complete Phone After Flash ставил? С меньшей скоростью пробовал? Точно делал по инструкции к SE-Tool, раздел "Восстановление аппарата" (Телефон не включается. При включении зависает, на экране нет изображения, подсветка включена (белый экран). )? Шил через DCU-60?
cancer
04-12-2007 13:33
На меньшей скорости точно, если советы Vada не помогут лей gdfs и делай разлок. Попробуй все снова иногда с первого раза не получается, потом из меню телефона сделай полный сброс.
prizrak_volk
11-12-2007 12:09
все перепробовал. еще на ремонт принесли K510 и такая же проблема. видимо дело в кривых руках. кто знает какую ошибку я допускаю?
Vad
Мобильщик
Мобильщик
11-12-2007 19:05
prizrak_volk, Где конкретные ответы на вопросы?
prizrak_volk
12-12-2007 13:36
я прошиваю прогой SETool2Lite1.08 все делаю по инструкции. не нашел где поставить Галочку на Complete Phone After Flash. скорость ставлю самую маленькую. шил через USB
Vad
Мобильщик
Мобильщик
12-12-2007 15:02
prizrak_volk, Нормальным SE-Tool-ом сделаешь. Lite - не поднимает аппараты, а только тупо прошивает (на то он и бесплатный)...
prizrak_volk
14-12-2007 09:36
Понтно!!! можно еще последний вопрос. Где взять нормальный сколько это стоит?
cancer
14-12-2007 10:21
стоит 3999 р покупал в GSMbaza, в интернете ссылок полно
vasiliy78
14-12-2007 16:25
prizrak_volk, www.gsmservice.ru если есть уфс можновзять только карту
Список форумов » Сотовые телефоны » Sony Ericsson » W300 Please wait
Текущий раздел » Сотовые телефоны » Sony Ericsson (Ремонт сотовых телефонов Sony Ericsson)
  • w300 белый дисплей
  • SE W300 не заряжается, при зарядке пикает
  • Sony Ericsson w300 не включается
  • Sony Ericsson W300 проблемы с сохранением.
  • Sony Ericson W300 не работает громкоговоритель
