Adjustment Method
How to enter Service 1
• Set the Bass to maximum position, set the Treble to minimum position then keep pressing the INDEX button on the
remote control and press the down button (-/v) on the TV set, this will place the TV set into the Service Mode 1.
Self Check
Self-check is used to automatically check the bus lines and hexadecimal code of the TV set. To enter Self-Check mode, keep
pressing the STATUS button on the remote control and press the down (-/v) button on the TV set. To exit Self Check,
switch off the TV set at the power button.
Display Ref. No. Description P.C.B.
E2 IC1120 EAROM A-Board
DPS IC1501 DISPLAY PROCESSOR AND SCALER A-Board
VSP IC1501 VIDEOSIGNAL PROCESSOR A-Board
AVSW IC1501 AV SWITCH A-Board
TUN TNR001 TUNER B-Board
MSP IC1501 MULTISTANDART SOUND PROCESSOR A-Board
DPL --- DOLBY PROLOGIC PROCESSOR ---
MAS --- MPEG1 AUDIO PROCESSOR ---
If the CCU ports have been checked and found to be incorrect or not located then " - - " will appear in place of "O.K.".
8
E2 O.K.
DPS O.K.
VSP O.K.
AVSW O.K.
TUN O.K.
MSP O.K.
DPL ---
MAS ---
TX-32LX60F TX-32LX60P TX-26LX60F TX-26LX60P
OPTION 1 0F 0F 0F 0F
OPTION 2 00 00 00 00
OPTION 3 B9 B9 B9 B9
OPTION 4 11 11 11 11
OPTION 5 00 00 00 00
OPTION 6 15 15 15 15
OPTION 7 FD FD FD FD
OPTION 8 D0 50 D0 50
OPTION 9 00 00 00 00
OPTION 10 00 00 00 00
OPTION 11 13 13 13 13
OPTION 12 20 20 40 40
OPTION 13 18 18 18 18
CHECK 06 86 26 A6
JinoA спосибо за схему но в сервиз попасть не могу.Здаётся мне чтото с памятью у него стало , после ночи полностью выключив пропадают все настроенные каналы.
JinoA мжет прошифка есть ? Заранее спосибо.
Всё добил!!! Во 2-ОЙ сервиз 99канал проходим в перовом до Sub-Brightness и на пуьте нажимаем (HOLD) .В Option12 значение(20) -DK,
Option 3 -(B9) Hiper.Тюнер надо менять ато метровых нету.
