Шасси телевизоров. Фото, состав,пульт!
Список форумов » Телевизоры » Кинескопные телевизоры На страницу Пред.  1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
киев
Прислонившийся
27-04-2014 23:13
PHILIPS 28PT550B/00 шасси GR2.4 AA
Philips 21PT4301, 21PT520B, 21PT522B, 21PT523B, 21PT5301, 21PT5301, 21PT530B, 21PT5321, 21PT532B, 21PT701B, 21PT701C, 21PT703B, 21PT703C, 25PT443A, 25PT472B, 25PT512C, 25PT522B, 25PT5301, 25PT530B, 25PT530C, 25PT5321, 25PT532B, 25PT5401, 25PT5402/00, 25PT540B, 25PT541B, 25PT542B, 25PT570B, 25PT622B, 25PT630A, 25PT7001, 25PT700B, 25PT7021, 25PT702B, 25PT720B, 25PT722B, 25PT727B, 28PT443A, 28PT472B, 28PT512C, 28PT520B, 28PT522B, 28PT530B, 28PT532B, 28PT5401, 28PT540B, 28PT541B, 28PT542B, 28PT550A, 28PT550B, 28PT552B, 28PW630B, 28PW632B, 28PW660B, 28PW662B, 29PT5301, 29PT530C, 29PT5321, 29PT5402/00, 29PT5501, 29PT5621, 29PT600B, 29PT602B, 29PT630A, 29PT632A, 29PT700B, 29PT722B, 29PT727B/25, 52TA4311/11, 52TA5213, 63TA4612, 63TA5212, 63TA6911, 63TA6912, 63TA7111, 63TB5192, 70TA4612, 70TA5212, 70TB4592, 70TB5192, 70WA6211, 70WB5191, 72TA6211, 72TA6911, 72TA6931
CPU: - TMP87CM36-3256
EEPROM: - 24С08
SMPS: - TDA8385, CNR50, BUT12AF
TR Chopper: - OREGA 40332-44
Video: - TDA4780, TDA4671
Pal/Secam: - TDA4510 / TDA4657
Delay: - TDA4665
Vertical Amp: - 2SD1266P, BD536
Horizontal/Vertical synchronization: - TDA2579B
HOT: - BU508AF.BU2520AF
FBT: - 1302.0001=25830031=HR7965=FBT-40385
RGB Amp: - BF422, BF423
SAW: - G3962M, G9350M
VIF: - TDA9815
Audio Amp: - TDA1521
Stereo Sound: - TDA9840, TDA9861
Switchboard TV/AV: - HEF4053BP
Teletext: - CF70200NW, CF702306
Tuner: - UV916
Tube: - A66EAK252X11
ПДУ: - RC7500, RC7507
IC remote: - ?
Code MAK: - ?
Светослав
14-10-2014 12:17
TVVCR Samsung TVP-3350IT Шасси SCV11A
SAMSUNG, (моноблок) Model TVP3350, TVP5050, TVP5350
Тунер: TECC2989PA19C
FBT: FTK - 14R008.
Проц скритый, 24C04 TDA8374A STRS6707 SAA5254 TDA8356 TDA7056 TDA4445 TDA4665 TC4053 TDA6101Q
Вход - Stand-By P.Std Menu Sleep Power On.
После входа в сервисный режим на экране появляется меню: Adjustment, Option byte, Reset.
Сокращения применяемые в режиме Adjustment:
AGC - Auto Gain Control,
SBT - Sub Bright,
SCT - Sub Contrast,
SCR - Sub Color,
STT - Sub Tint,
PDL - Pal Delay,
NDL - NTSC Delay,
RC - Red Cutoff,
GC - Green, Cutoff,
BC - Blue Cutoff,
RG - Red-Green drive gain,
BG - Blue-Green drive gain,
PSL - PAL vertical SLope,
PVS - PAL Vertical Shift,
PVA - PAL Vertical Amplitude,
PHS - PAL Horizontal Shift,
NSL - NTSC vertical SLope,
NVS - NTSC Vertical Shift,
NVA - NTSC Vertical Amplitude,
NHS - NTSC Horizontal Shift.
OPTION
BIT ITEM 0 1
7 TTX NOTTX TTX
6 TTX SYSTEM TTX SYSTEM FLOF FIRST
5 CONTRAST 90 100
4 TUNER QUANTITY 1 2
3 TUNER KINDS 2889 0889
2 SYSTEM (L)
1 SYSTEM (D/K)
0 SYSTEM (I)
OPTION 2
BIT ITEM 0 1
7 NOT USED
6 NOT USED
5 POWER ON AFT ONCE TWICE
4 PDC NO YES
3 VPS NO YES
2 3.58 X-TAL NO YES
1 VIDEO PLUS NO YES
0 SHOWVIEW NO YES
VCR OPTION
BIT ITEM 0 1
7 NOT USED
6 NOT USED
5 NOT USED
4 HEAD 2-HEAD 4-HEAD
3 SP/LP SP-ONLY SP/LP
2 SECAM N/A POSSIBLE
1 MESECAM N/A POSSIBLE
0 NTSC3.58 N/A POSSIBLE
Опции 194 и 32
Светослав
05-06-2015 14:25
TV Tecnimagen 29TXS Real Flat
Шаси CTG AA
FBT - 13525091C Tuner - KS-H-148
uP - TDA9353PS/N3/1/1897
TDA9875
TDA8358J
TDA7297
TDA6107JF
ICE1QS01
Enter in Service mode:
- Select program 75 and press at the same time OSD key (+) on RC and MENU key on local key board during 4 seconds.
Service mode is indicated by an S symbol on the down left corner of the screen.
schizm
12-04-2018 21:47
http://monitor.net.ru/forum/viewtopic.php?t=305871&postdays=0& ...
AKAI CT-21WKD
B20 ----------------------------------- шасси (схема)
MN152810 (кwмcc) ------------- проц.
24С04 ------------------------------- память (прошивка)
AN5195K-C ------------------------ в/проц.
AN5071 ----------------------------- ком. диап. и cтабилизатор +31v
AN5637 ----------------------------- секам
AN5534 ----------------------------- кадры
AN5265 ----------------------------- унч
MN3868 ---------------------------- задержка
FCM-21A004 +2SD2499 ----- вкср
TECC2989VA24B -------------- тюнер
2SD2498 --------------------------- ключ "китайского" бп
A51KPO12XX -------------------- элт
стоит реально JF0501-0902 +2SD2499,
а по схеме FCM-21A004 + 2SD1555
Leha
12-04-2018 21:53
schizm писал:
и че?
С Новым Годом?!!! Чудной
schizm
12-04-2018 22:06
Leha писал:
schizm писал:
и че?
просто анекдот
- Не пытайся понять то,что тебе понять не дано.
- Не понял?
- И не пытайся. подмигивание
Leha
12-04-2018 22:55
schizm, тебя мало за флуд дрючили? Третье предупреждение = автобану.
kin369
19-01-2019 09:51
      LUXEON TL-2165S
MAIN - MEK TOP+USB V2.00
UOC - TDA11136PS/N3/3(NT11136PC301AG)
MEM - FM24C08
SMPS - FSCQ0765RT
TR CHOPPER - BCK-70-04K1(BCK-65-01)
SAW - K2959M
SOUND - TDA17821
VERT - LA78040B
HOT - MD1803DFX
FBT - DST2010-N11(BSC25-N0627)
AV - CD4052
TUNER - UVC66K5VCA
RGB Amp - BF422, BF423, 2SC2330
TUBE - A51ERS357X440
ON/OFF - 120V/75V
SIZE - 245x237(246)
REMOTE - UOC TOP(ZD)
IC remote - UPD6122
      Для входа в сервис нажать [MENU] и набрать 6483. Режим [B/W BALANCE]. [MUTE] отключает кадровую, [CALL / "?"] переключает [MENU]-[FACTORY]-[LOGO]. [MUTE] листает страницы меню. Расширенное меню - в [MENU 2] [SETUP SELECT] установить в [1].
kin369
30-01-2019 20:38
      JVC AV-2155YE шасси CW
Main - GGB10010-001G(SCW-1406A D201ERU)
UOC - TDA12020H/N1D01
Memory - 24C16A
SMPS - STR W6754
TR CHOPPER - QQS0273-001
SAW1 - SB6351/N1539
SAW2 - K7267D/IRT9
Sound - AN5276
Vert - LA78040N
HOT - 2190
FBT - JF0501-3241(QQH0189-001)
RGB Amp. - TDA6107AJF
Tuner - TECC7949PG40J
Other IC - SE115; MM1561JF-X
ON/OFF - 115V/115V
REMOTE - RM-C1280
IC remote - NEC 2313L
      Для входа в сервис нажать на RC [DISP]+[P.MODE]. Эта комбинация поддерживается только в оригинальных пультах. Выбор группы цифровыми кнопками, возврат [DISP]. Для входа в SYSTEM CONSTANT снова нажать на RC [DISP]+[P.MODE]. В некоторых группах кнопка [MEMU] выбирает дополнительные подгруппы. Выход из меню [DISP]. Также в сервис можно войти подачей команды 6A по адресу 0003.
kin369
08-02-2019 21:53
      TEVION TV-5560VT STEREO шасси BEKO 16.1
MAIN - ZA4.190-07
MICOM - ST90195C7B1/PFK
MEM - 24C08
SMPS - TDA16847P+P4NK60Z
TR CHOPPER - 2084.0100
VIDEO - STV2246C
SAW - G1985M
STEREO - MSP3401G B8 V3
SOUND - TDA8944J
VERT - TDA8174AW
HOT - BU808DFI
FBT - 1142.1816B
TUNER - ENV57D60G3
RGB Amp - BF421, 2SC2482
TUBE - A51EER33X78
SIZE - 250x285
REMOTE - RC-7SZ206
      Для входа в сервис на пульте RC-5 с раздельными регулировками нажать [контрастность-], что соответствует подаче команды 1D по адресу 00.
kin369
19-02-2019 20:04
      TOSHIBA 21LSR78
MAIN - PE0148 / R-8705 (стикер A-21LSR78-LJE2301-0046)
UOC - TDA12020H/N1F00; SD0924.1; CF7764; ZSG0617 N1F
MEM - 24C16A
SMPS - STR F6267
TR CHOPPER - TPW3577AW
SAW - BSF9351K; BSF6284K
SOUND - AN5277
VERT - AN5523
HOT - D2539
EW - STK630
FBT - BSC23-N0161(TFB4229AG)
TUNER - ENV59DA7G3
RGB Amp - TDA6107AJF/N1
OTHER IC - SE125; KIA78D33; AN34040A
TUBE - A51ERS420X03
SIZE - 250x330
ON/OFF - 125V/40V
REMOTE - CT-90229
IC remote - PBF C49 6227A
      Вход в сервис : нажать MUTE, потом вместе TVMENU и RCMUTE.Будет режим S. Для входа в расширенный режим D, в режиме S нажать вместе TVMENU и RCCALL. -/-- - отключение кадровой, AV - тестовое поле, 9 - SELF CHECK, SUBPAGE - TUNER CHECK, POWER - выход. Протокол NEC, адрес 40, команда B7 - вход в режим S; команда B5 - вход в режим D, она же выход из сервиса.
kin369
11-03-2019 19:11
     ORION SPP2920FL
MAIN - LP25A-64A
UOC - TDA9381PS/N3/2/1831
MEM - K24C08
SMPS - 5Q1265RF
TR CHOPPER - PEC24-1265(BCK-24011)
SAW - F38.9H
SOUND - AN17821A
VERT - STV9325
HOT - 2SC5297
FBT - BSC25-N0539
AV - HCF4052BE
TUNER - EWE-1053-V
RGB Amp - BF422, BF423, 2SC2688
TUBE - A68EMN021X0A1
SIZE - 245x330
ON/OFF - 135/90
REMOTE - WH-55A-3 (BT-0305A)
IC remote - UPD6122
RCCreator - 315510F02FA2050E6B7
Для входа в сервис нажать [Menu], [6],[4],[8],[3], войдём в режим [M]. Выбор меню [1]-[4], выход [POWER] на RC. Для входа в расширенное меню в режиме [M] нажать [Time], [Lock], [5], [Time], [Lock], [5]. Выбор меню - [0], [5]-[9]. Логотип - в режиме [M] нажать [Cal]. [AV] - выбор параметра, [Disp] - выход.
Список форумов » Телевизоры » Кинескопные телевизоры » Шасси телевизоров. Фото, состав,пульт! На страницу Пред.  1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11
  • Идентификация шасси телевизоров
  • Пульт на Тв Шасси 200-100-TV2K
  • пульт SHARP шасси 11AK45
  • Palladium шасси PT-90 пульт не рулит DVD
  • SIEMENS FS 362 шасси CS 9409 ПУЛЬТ?
