Ликбез ЧПУ,-тема для начинающих!
Список форумов » Промышленная электроника На страницу Пред.  1, 2, 3
andreieinav
19-11-2012 15:09
Продолжу выкладывать основные неисправности SINUMERIK-810D,840D.
2-15
© Siemens AG, 2006. All rights reserved
SINUMERIK, SIMODRIVE Diagnostics Manual (DA), 11/2006 Edition
Overview of Alarms 2
Product: , Version: 1.0, Language: eng
2.1 NCK ALARMS
0 No (more) alarm(s) present
Definitions: If the communication (variable service) requests more alarms than currently available in the alarm list,
this alarm is communicated as end-of-program function.
Reaction: No alarm reaction.
Remedy: --
Program
Continuation:
Internal
1000 System error %1
Parameters: %1 = System error number
Definitions: With this alarm, internal alarm states are displayed that, in conjunction with the transferred error
number, provide information on the cause and location of the error.
Reaction: NC not ready.
Channel not ready.
NC Start disable in this channel.
Interface signals are set.
Alarm display.
NC Stop on alarm.
Remedy: Make a note of the error text and contact Siemens A&D MC, Hotline
- Tel 0180 / 5050 - 222 (Germany)
- Fax 0180 / 5050 - 223
- Tel +49-180 / 5050 - 222 (International)
- Fax +49-180 / 5050 - 223
- email
Program
Continuation:
Switch control OFF - ON.
1001 System error %1
Reaction: Mode group not ready.
Channel not ready.
Alarm display.
Remedy: Make a note of the error text and contact Siemens AG A&D MC, Hotline (tel./fax: see alarm 1000)
Program
Continuation:
Clear alarm with the RESET key in all channels of this mode group. Restart part program.
Добавлено 19-11-2012 15:11
Overview of Alarms 11/2006
NCK alarms
2-16
1002 System error %1
Reaction: Alarm display.
Program
Continuation:
Clear alarm with the Delete key or NC START.
1003 Alarm pointer for this self-clearing alarm %1 is zero
Parameters: %1 = Incorrect alarm number
Definitions: The address (zero pointer) used by the compile cycle manufacturer or by the operating system for selfclearing
alarms is not allowed in the system.
Check setCCAlarm/setAlarm (...) call.
Program
Continuation:
1004 Alarm reaction to NCK alarm incorrectly configured
Definitions: The alarm reaction configured by the operating system or the compile cycles manufacturer is
incorrect.
Channel not ready.
Alarm display.
Change alarm reaction
Program
Continuation:
1005 Operating system error %1 parameter %2 %3 %4
Parameters: %1 = Operating system error number
%2 = Operating system error parameter 1
%3 = Operating system error parameter 2
%4 = Operating system error parameter 3
Definitions: This alarm indicates that the operating system has detected a serious error.
Channel not ready.
Alarm display.
NC Stop on alarm.
Program
Continuation:
Добавлено 19-11-2012 15:14
NCK alarms
2-22
2100 NCK battery warning threshold reached
Definitions: The undervoltage monitor of the NCK battery has reached the prewarning threshold. This is at 2.7-2.9
V (nominal voltage of the battery is 3.0-3.1 V at 950 mAh).
Remedy: Please inform the authorized personnel/service department. The battery must be replaced within the
next 6 weeks. After this period, the voltage can drop below the alarm limit of 2.4-2.6 V if the RAMs to
be buffered take up a lot of current.
Program
Continuation:
2101 NCK battery alarm
Definitions: The undervoltage monitoring (2.4 - 2.6 V) of the NCK battery has responded during cyclic operation.
Remedy: If the NCK battery is replaced without interrupting the power supply, no data will be lost. This means
that production can continue without taking any further steps. (A buffer capacitor on the NCK holds
the supply voltage for at least 30 minutes and the battery can be replaced within this time even when
the control is switched off).
Program
Continuation:
2102 NCK battery alarm
Definitions: The undervoltage monitoring (2.4 - 2.6 V) of the NCK battery was detected during system power-up.
The NC switches to follow-up mode.
Channel not ready.
Alarm display.
NC Stop on alarm.
Remedy: Please inform the authorized personnel/service department. Pull out the battery/fan unit from the NC
module and replace the battery (type: lithium battery with lead, size 1/2 AA, 850 mAh, min. 3.2 V).
The system must then be reinitialized because it must be assumed that data has been lost in the
buffered RAM during the last power-off phase as a result of insufficient supply voltage (refer to Section
2.2 in the Installation and Start-up Guide for the procedure).
The following data might have been corrupted or entirely lost:
- NC machine data
- Drive machine data
- Option data
- Setting data
- User variable
- Global subroutines
- Cycles and macros, as well as
- PLC machine data
- PLC basic program
- PLC user program, and all
- PLC user data
User data in the NCK and PLC (e.g. tool and workpiece data) that have been altered by the
manufacturing process since the last data backup must be updated manually to match the present
machine status!
Program
Continuation:
Добавлено 19-11-2012 15:16
NCK alarms
11/2006 Overview of Alarms
2-23
2110 NCK temperature alarm
Definitions: The temperature sensor has reached the response threshold of 60 degrees C +/- 2.5 degrees C.
Remedy: In order to reset the sensor, the temperature must be reduced by 7 degrees C.
Program
Continuation:
2120 NCK fan alarm
Definitions: The fan consists of a 26 V DC motor with electronic commutator (rated speed: approx. 8700 rpm). The
commutator signal is used for speed monitoring, response speed: < 7500 rpm.
Remedy: Please inform the authorized personnel/service department. The unit with the fan and NCK battery
must be replaced.
Program
Continuation:
2130 5V/24V encoder or 15V D/A converter undervoltage
Definitions: A failure has occurred in the power supply (FM357-2) to the encoder (5V/24V) or D/A converter (+/-
15V).
Mode group not ready, also effective for single axes
Axes of this channel must be re-referenced.
Alarm display.
NC Stop on alarm.
Remedy: Please inform the authorized personnel/service department. Check the encoder and cable for shortcircuits
(the fault should not occur when you remove the cable). Check the power feeder line.
Program
Continuation:
2140 The actual service switch position forces the SRAM to be cleared at the
next Power On (general reset active)
Definitions: The initialization switch is currently set to overall reset. This means that the module's SRAM is deleted
with the next module reset. The NC data memory is cleared during this operation.
Alarm display.
Remedy: Reset initialization switch to zero.
Program
Continuation:
Alarm display showing cause of alarm disappears. No further operator action necessary.
2190 Hardware plug-in module for communication with the digitizer missing
Definitions: MD $MN_ASSIGN_DIGITIZE_TO_CHAN was used to activate the digitizing function by assigning it
to a channel. The function requires a hardware module (RS422 board plugged into the NCU) for
communication with the digitizing unit. This module was not found when booting.
Reaction: Interface signals are set.
Alarm display.
Remedy: Please inform the authorized personnel/service department. Plug in communications module or
cancel channel assignment.
Program
Continuation:
Добавлено 19-11-2012 15:20
NCK alarms
2-24
2192 No NCU link module exists, MD %1 reset
Parameters: %1 = String: MD identifier
Definitions: An attempt was made to activate the NCU link functionality but the hardware is not available. The MD
was reset. Only occurs with the NCU link system
Channel not ready.
Alarm display.
NC Stop on alarm.
Remedy: Install the hardware module and activate the function again (MD).
Program
Continuation:
2193 'Safety Integrated' is not available for link axis %1.
Parameters: %1 = Machine axis index
Definitions: The "Safety Integrated" function is not available for a link axis. Only occurs with the NCU link system
Channel not ready.
Alarm display.
NC Stop on alarm.
Remedy: Use "Safety Integrated" function for local axes only.
Program
Continuation:
2194 Link axis active and $MN_MM_SERVO_FIFO_SIZE != 3
Definitions: At least one axis is to be distributed via NCU link, then the machine data
$MN_MM_SERVO_FIFO_SIZE must be 3. Occurs only with an NCU link system.
Channel not ready.
Alarm display.
NC Stop on alarm.
Remedy: Set $MN_SERVO_FIFO_SIZE to 3.
Program
Continuation:
2195 Channel %1 axis %2 high-speed punching/nibbling not possible via link
Parameters: %1 = Channel number
%2 = Axis name, spindle number
Definitions: An attempt was made to activate high-speed nibbling or punching for an axis programmed on a
different NCU than the drive.
Channel not ready.
Alarm display.
NC Stop on alarm.
Channel not ready.
Remedy: High-speed nibbling and punching is only supported on one NCU.
Program
Continuation:
Добавлено 19-11-2012 15:35
Еще раз повтoрю,что"ALARM TEXT" любой машины CNC дает лишь направление поиска проблемы!NCK alarms
2-83
6581 NC user memory full
Definitions: The DRAM file system of the user area is full. The order cannot be executed.
Remedy: Delete or unload files (e.g. parts programs)
Program
Continuation:
6582 NC machine OEM memory full
Definitions: The DRAM file system of the machine OEM area is full. The order cannot be executed.
Program
Continuation:
6583 NC system memory full
Definitions: The DRAM file system of the system area (Siemens) is full. The order cannot be executed.
Program
Continuation:
6584 NC memory limit TMP reached
Definitions: The DRAM file system of the TMP (temporary) area is full. The job cannot be executed.
Remedy: Increase machine date $MD_MM_DRAM_FILE_MEM_SIZE or switch off the precompilation of
individual or all cycles or, if need be,
delete the files in the TMP area.
Program
Continuation:
6585 NC external memory limit reached
Definitions: The DRAM file system of the external area (execution of the external drive) is full.
Remedy: Load the files to be executed explicitly into the NCK.
Program
Continuation:
6600 NC card memory is full
Definitions: The NC card file system of the NCK is full. No more data can be stored on the NC card.
Remedy: Delete the data on the PCMCIA card.
Program
Continuation:
6610 Too many files open on NC card
Definitions: Too many files are being accessed simultaneously on the NC card.
Remedy: Repeat the action later.
Program
Continuation:
KENT
24-11-2012 09:45
driving писал:
Первой заповедью наладчика должно быть,-не навреди!Второй заповедью,-читай умные книжки!
Истину глаголешь !
Приятель две недели за свой счет звонил на Сицилию ,чтобы востановить параметры.
Машина спросила у него :
провести ли инициализацию системы?
и он ей ответил- Да! :-) ...[/quote]
+1
andreieinav
10-01-2013 14:22
В личку пришел вопрос;
-"Есть ли возможность в цифровых машинах отменить линейки и работать с помощью резольвера,расположенного на сервомотре?"
Отвечаю;
-можно,но не нужно!Поясню!Линейки на цифровых машинах позволяют добиться очень выcокой точности обработки деталей.Соответственно,если возникает механический износ муфт,червяков и т.д. ,то, в первую очередь,это фиксирует линейка,кот. является устройством обратной связи(фидбек).Таким образом,-отмена линейки может привести к полному бардаку с размерами,хуже того,-бывали случаи когда из-за отмены линейки разносило оси машины.
Поэтому,если хотите отменить линейку и перейти на резольвер ,-сто раз подумайте!!Я это делать не рекомендую и не советую!
andreieinav
17-04-2013 14:33
Интересный вопрос пришел в личку
"...отсоедeнил кабель энкодера на машине "HITACHI SEIKI" и не могу запустить ось,на драйвере неисправность "11"...
Вот тут нужно знать несколько интересных вещей;
1 существуют энкодеры,где информация и некоторые параметры хранятся в памяти,которая поддерживается 6-ти вольтовой батарейкой,находящейся на драйвере.
2 прежде чем дергать кабеля энкодера,нужно внимательно почитать умную книжку про привод
3"11"-говорит о том,что драйверу(FANUC -A06B-6093-H151,как правило) нужно прописать нулевую точку и указать направление движения в "+"и"-"
Эти тонкости характерны для многих машин японского и тайваньского производства.Поэтому,прежде чем отсоединять кабель энкодера ,изучите описание,если оно есть,-если его нету-внимательно рассмотрите драйвер;-батарейка должна быть на видном месте!
vef99
15-06-2013 11:56
andreieinav, можете и мне скинуть книги на почту?
vlad1974
19-06-2013 21:30
Всем Доброе время суток.
У меня возникла необходимость порыться в программе работы PLC SYSMAC CQM1 OMRON. До этого ни разу ПЛК не программировал. Кто сталкивался с таким ПЛК прошу подсказку: какой переходник необходим для подключения его к компу и какой программой можно стянуть прошивку, отредактировать и снова ее залить в ПЛК?
andreieinav
20-06-2013 13:56
vef99 писал:
Какие книжки тебя интересуют кокретно?
Добавлено 20-06-2013 14:08
vlad1974 писал:
Начнем с того,что в интернете есть инфа по этим PLC.Переходник можно слепить самому,-но начать нужно с принципа программирования таких контроллеров,т.е. с "легенды",или еще говорят,-с логики работы машины.Cоставь сам себе техзадание и решай его пошагово!Научиться работать с "LADDER" контроллеров,-не такое простое дело!
vlad1974
20-06-2013 18:06
Дело в том, что таких ПЛК на машине 3шт. Работают они подобно, но в одном уже ктото программно порылся. Мне необходимо слить программу работы с одного рабочего и исправить ошибку в нерабочем по аналогии .Заменить ее программой с рабочего нельзя т.к. к этому ПЛК подключено еще несколько датчиков. Поэтому основная проблема для меня слить и залить программу. Редактировать ее - дело уже второе....
vlad1974
27-06-2013 17:54
andreieinav, есть ли у Вас какая нибудь литература по LADDER на русском? Чтото ничего не могу найти....Если есть - прошу скинуть на мне почту.Заранее благодарен.
andreieinav
01-07-2013 11:57
vlad1974 писал:
На русском не нашел,но на английском инфы по LADDER как грязи,на любой вкус.Тебе не обязательно вникать в тонкости,тебе нужно научться перекачивать программки с одного PLC на другой.
vvc
22-08-2014 12:57
andreieinav писал:
vef99 писал:
Добрый день.
Может проще создать в разделе "файлы - документация" папку " Пром электроника" и туда загрузить документацию имеющуюся в наличии ?...
Остальные пользователи дополняли бы библиотеку. Лично у меня есть много документации по Siemens..
Андрейкак
06-06-2015 09:51
Подскажите, пожалуйста в чем отличие Sinumerik 840D и Sinumerik 840С.
UMVolt
14-06-2015 23:27
Почему работодатели требуют от электроника по ремонту и обслуживанию высшего образования? В какую вакансию ни глянь - везде хотят вышку. Кто ввёл такую систему рёв в три ручья ? Избыток инженеров - электроников (не "фейковых")?
Особенно отдел кадров - просто непроходимая преграда. Считают что человек со средним не может освоить профессию?
DocR
13-01-2016 16:41
Не первый раз уже сталкиваюсь. На sinumeric 840D появляется ошибка NCU fan alarm. Ну например появилась ошибка, на NCU box вентилятор реально плохо крутится - вроде как неисправность понятна, заказываем блочек (или заменяем с другого станка). Вентилятор крутится уже вроде как и нормально, но ошибка никуда не девается. Первый раз когда столкнулся, производитель станка, после дистанционной диагностики предложил замену NCUbox(чем закончилось не знаю). Сейчас в другом месте та же проблема.
Все же хочу немного понять, может есть процедура какая замены, где в мануале расписано. Ну то что менять под питанием это понятно. Далее что необходимо сделать? Есть ли возможность наблюдать кол-во оборотов вентилятора. Бывают ли действительно случаи выхода из строя NCU с такой ошибкой, есть ли смысл открывать ковырять его?
Спасибо!
anatoly_k_57
13-01-2016 18:56
С такой ошибкой сталкивались несколько раз. Один раз замена вентилятора (сгорел), остальные чистка и смазка. Вообще извлекать лучше после снятия питания в течении 10-15 минут необходимо вынуть из бокса вентилятор, а бокс с батареей на место - один раз "слетело" NCK. Залили из архива Да, если не отключая питания вынуть и вставить бокс - не сбрасываются ошибки батареи и фена!
DocR
13-01-2016 22:06
Это получается там ионистор ещё предусмотрен?
Сброс(ресетом на NCU) делали и перезапускали станок само собой не раз.
anatoly_k_57
14-01-2016 12:36
Не помню точно в Фануке или Симменсе, сигнал контроля вращения - импульсы! Т.е. нужен фен такого же типа, как и был. Кстати, несколько починили заменив полевик (SMD) на выходе контроля - они почему-то чаще всего сгорают. Обороты не знаю где смотреть, но фен тормозили в-половину - ошибка.
andreieinav
14-01-2016 14:28
DocR писал:
Спасибо!
Я уже описывал такую неисправность в теме про "SINUMERIK"!Точно страницу не незову,(надо поискать!),но суть дела сводится к тому,что вентилятор на NCK контроллере хитрый и выдает не уровень,как в FANUC ,а прямоугольные импульсы,скважность которых зависит от скорости вращения вертушки,т е если он забит маслом,заклинил и т д и т п ,-меняется скважность,-появляется неисправность и машина блокируется!Все просто,парни!Купите фирменный вентилятор и все заработает!
Будьте проще,-к вам потянутся люди! Крутой!
gnu
14-01-2016 16:33
andreieinav писал:
То-то я тебе генератор импульсов городил гы-гы
DocR
14-01-2016 18:57
Сегодня немого повозились со станком, давайте подробней опишу. Случай такой не первый, как я уже узнал, закончилось заменой NCU в первом случае. Значится так вылезло сообщение "NCK alarm fan" при включении приводов вылезает уже ошибка по температуре, которая уже и не дает работать. Что сделано, заменены 2 блочка с вентиляторами/батарейкой с исправных станков, на всякий случай разобрали и почистили эти вентиляторы, почищен вентилятор процессора(он очень плохо крутился) внутри NCU - ничего не меняется. Ошибка по температуре появляется сразу после включения управления, даже если станок долго стоял, слабым напором воздуха охлаждали и включали. Может нужно ошибку эту как-то стирать после устранения неисправности? Могу ли я наблюдать обороты вентиляторов и температуру как-то? Сейчас снял NCU для поиска датчиков температуры, может нарою чего.
https://cloud.mail.ru/public/9kTz/zG7Xk9Bca
https://cloud.mail.ru/public/29U5/bbDxTLwBB
Добавлено 14-01-2016 19:14
Сенсор температуры TC620n
shaw_ton
Добрый день, уважаемые форумчане. Требуется ваша помощь и совет. Имеется такой комплект серводвигателя HIGEN FMA-LN12-AB00PES (11.5 N*m, 1000 s-1) 3 шт. и серводрайвера HIGEN FDA-5020R (200 - 230V, 16A) 3 шт. Также есть Allen - Bradley IMC - S/234 Compact four-axis servo motion controller. Что еще нужно их "железа" для полноценного ЧПУ фрезера по 3 осям? Как сконфигурировать сервопривода?
andreieinav
01-06-2016 14:21
shaw_ton писал:
Подожди,-ты хочешь сваять CNC из разношерстных шаробаек?!Если так,то начинать надо с постановки задачи и определения сил и средств ,имеющихся в наличии!
kratmel
02-06-2016 09:06
Насчет конфигурации
HIGEN FDA-5020R - то штатный софт с сайта производителя до последнего времени не соединялся нивкакую с такими драйверами. Пробуйте может вам повезет и вы найдете подходящий не кривой софт.
Я для себя купил панель внешней конфигурации - через нее переписываю нужные мне параметры для приводов которые приходится менять (смотр стр 4.1
мануала)
shaw_ton
Добрый день. Andreieinav данная подборка (HIGEN motor+HIGEN driver+Allen Bradley+управление SIEMENS S7-315DP) уже работала, только с другим антуражем, линия розлива пищевых продуктов. Почему данный комплект нельзя использовать в постройке ЧПУ? Просто моя познания в конфигурировании сервоприводов нулевые. Документация и программа конфигурирования с сайта производителя, не кривая.
Добавлено 03-06-2016 09:30
Только какие параметры нужно конфигурировать? Да, про панель внешней конфигурации, уважаемый kratmel, не подскажите где можно такую приобресть? Из управляющего модуля есть 2 варианта: NC-210 от БАЛТСИСТЕМ или просто компьютер с установленной MACH3.
valer
09-04-2017 12:27
кто знаком с частотником китайского производства Huanyang HY02D223B
Murka
Профессор
09-04-2017 13:18
valer, Гугля очень знаком, даже русские инструкции находит.
Kempr
21-07-2017 21:00
Если у кого возникнут проблемы с настройками Роландовских ЧПУ https://engraver.ru/products/frezernye-stanki/ - обращайтесь в их демозал, они помогут решить проблему и покажут на своих как правильно работать.
IgorAR
21-11-2017 07:42
Вроде бы все так хорошо начиналось и темка хорошая. Но видимо нет пути для ее развития?
Список форумов » Промышленная электроника » Ликбез ЧПУ,-тема для начинающих! На страницу Пред.  1, 2, 3
Текущий раздел » Промышленная электроника (Ремонт различной промышленной электроники (ЧПУ, и тд))
  • Ликбез про электродвигатели и приводы
