Тестируем програматор SPI FlashROM 25VF080
Список форумов » Программное обеспечение На страницу Пред.  1, 2, 3, 4  След.
RayeR
Hello doodz,
my SPIPGM core was joined into flashrom.org project - the multiplatform univerzal flahing tool. So now you can program via LPT port much more SPI flash chips улыбка There was also introduced 32bit DOS/DPMI version, you can download here:
http://khepri.coresystems.de/~idwer/flashrom/
You need to pass "-p rayer_spi" option to use LPT port programmer interface.
We did some tuning and testing so now the read speed is near the same as SPIPGM but erase speed is much longer due to forced verification. Also don't be confused, this version is not yet completed and there's missing some progress indicator (keep computer working it's not hanged улыбка
I hope you will like it. Anyway I will keep sometimes updating my SPIPGM because it would be needed the win32 version (win32 flashrom port is very obsolete).
Postal2
30-07-2010 03:11
RayeR, we have own prog, with much more possibilities. Last is here:
http://monitor.net.ru/forum/download.php?id=146234
Driver for XP here:
http://monitor.net.ru/forum/download.php?id=125785
Driver for 98 here:
http://monitor.net.ru/forum/download.php?id=145651
(пусть попробует, оно всё на пользу улыбка )
RayeR
>Postal2
Interesting SW, is there some desceription how to connect various hardware that it supports?
In SPIFlash menu I saw tha flashchip list and it's very limited. Look at the flashrom support list улыбка
Postal2
01-08-2010 14:48
RayeR, select 74HC244 for your (standart) hardware, and try ANY spi-flash chip (from your "support list" гы-гы ), but size set manually. Set delay to "0" (or near, default=10) in LPT settings to increase speed. Other hardware is mainly for I2C connect, SPI was added because very simple (and eliminates third party bugs улыбка ).
(объяснил, как подключить, и что прога для I2C в основном)
balagur72
Гость 95.155.*.*
20-09-2010 14:56
Уважаемые форумчане, ткните носом где найти схему на программатор SPI_TT?
БМК
20-09-2010 15:14
balagur72, гугл рулит
http://www.google.com/search?client=safari&rls=en&q=программат ...
Postal2
20-09-2010 17:22
balagur72, там в файле SPI Flasher.jpg она. Собирай улыбка .
http://monitor.net.ru/forum/viewtopic.php?t=356301#2630612
batya007
Гость 217.174.*.*
16-03-2011 20:04
[img][/img]
  spi.png  49,22 КБ  Скачано: 4833 раз(а)
yreks
Гость 92.113.*.*
16-04-2011 23:16
вобше можно обойтись без микросхемы буфера,питание можно поставит от сотки
Обошелся без микросхемы - работает.... Работаю етой прогой http://www.spiflash.org ...
Как снимать защиту на флеши?????
Руслан241
17-05-2011 20:54
Наткнулся вот на это http://forum.baraxla.net.ua/index.php?/topic/7-shema-proshivka-i-programma/
Может кто уже повторил?
Скорость подкупает
Скорость чтения 8 мегабитной микросхемы (W25Q80) 9-13 cек.Скорость записи этой же микросхемы 15-18 сек.
Nikolaevich
20-05-2011 21:08
Я его уже выкладывал - посмотри тему http://monitor.net.ru/forum/viewtopic.php?t=378240&postdays=0& ...
НО НИКТО ВРОДЕ НЕ ЗАИНТЕРЕСОВАЛСЯ.
одобряю
dmibr
20-05-2011 22:56
Я очень даже интересуюсь, давно хотел собрать программатор SPI-FLASH USB. Пока купил детали, как соберу отпишусь.
Nikolaevich
21-05-2011 12:12
dmibr, пожелание тебе - внимательно почитай совет автора
Даю совет сразу делать программатор UsbProg_FT245RL_Mega8515 в основном этот программатор и будет поддерживаться новым Firmware.
А ты начинаеш отвечать -не смог найти RL она на доллар дороже, может Вы все перепишете недовольство, огорчение .
dmibr
21-05-2011 12:47
У нас ft245bm продают за $5,56, а RL нужно ждать около месяца и цена $9,11. Я ждать не хочу, интересно быстро собрать устройство на том что есть и проверить в работе. Конечно, если автор не забросит проект и добавит в программу поддержку других серий флэшек (пока я отправил ему два даташита: 25T80 и A25L080), то позже приобрету рекомендуемые мс.
fsem
21-05-2011 13:00
Жителям Украины и не только:
FT245RL = http://www.kosmodrom.com.ua/product.php?page=0&name=FT245RL&ok ... = 38.02грн = 4.75$
Mega8515 = http://www.kosmodrom.com.ua/product.php?page=0&name=Mega8515&o ... = 20.34грн. = 2.54$
Руслан241
21-05-2011 15:45
Я думаю лучше подождать,как советует автор.
У нас тоже проблема с FT245RL,заказал в местном магазине.
Стоить говорят будет около 200 рубликов.
dmibr
23-05-2011 23:52
Руслан241, Девайс по ссылке работает. Сегодня собрал и проверил на EN25F80, D80 и Winbond W25d80. Скорость очень быстрая. Так что можешь собирать на BM-ке. У меня на FT245BL, правда немного пришлось повозиться с её программированием. Для работы нужна программа MProg и драйвер -- всё есть на сайте изготовителя http://www.ftdichip.com/Support/Utilities.htm.
Nikolaevich
07-06-2011 19:56
Я как бы не прав, по поводу обновлений на http://forum.baraxla.net.ua/index.php?/topic/7-shema-proshivka-i-progr ... .
Вчера АВТОР выложил обновление программы ! одобряю
Нужно будет подкорректировать свое предыдущее сообщение.
Мясковский
Молдованин писал:
После неудачного обновления БИОС на MS-7369 пришлось перешивать 25Х80. Использовал старенький ноут, так как лазить постоянно в комповую задницу было неудобно. Для питания выносной , регулируемый блок питания. Сначала сделал все как у чеха, с резисторами. Подпаялся прямо к ножкам. Микросхема не определялась, стерлась правда быстро. А вот читалась и писалась очень долго( 10% в час). После долгого чесания репы выкинул резисторы и напрямую подключился к разъему. Микра сразу определилась, прочиталась , прошилась. Прошилась правда со второго раза, но это скорее косяк в прошивке был. После этого пытался шить 25L4005. Определилась, считалась, стерлась, записалась. Проверить правда не смог. Мать GA-M615 оказалась совсем убитой.
То есть ты просто взял ноут с LPT и кабель подцепил провода на выводы микросхемы без резисторов,и прочей хреноты на прямую и прошился? можно схему как подключал, что к каким выводам подключал?
parovoz
17-08-2011 15:02
Помогите с прошивкой. У меня SPIFlash programmer 1.8 прекрасно читает и шьет. Нужно прошить Pm25FV010 к монитору Samsung 204B. Есть прошивка в HEX, занимает 340 kb, Микросхемка объемом 128 kb. Как её туда вогнать? Может у кого-нибудь "bin" этой прошивки есть?
Aliaksandr
17-08-2011 19:28
parovoz Можно ЛОШОДЬЮ открыть формат hex и затем конвертировать в bin.
Ilhom1122
Гость 83.221.*.*
26-09-2011 16:43
pm25lv010 mikcro sxemu na monitor Acer 1916W a
Добавлено 26-09-2011 16:45
mojno proshivka ACER 1916w a monitori
Injenercrb
01-11-2011 12:37
shoorik писал:
прошивает и читает и стирает микросхему 25L8005 без проблем с SPI Flash Programmer v1.8 Rus.rar СПАСИБО! ВСЕМ
Добавлено 27-02-2010 23:09
со схемой через LTP и 3.3 v
  1.rar  73,06 КБ  Скачано: 394 раз(а)
Собрал данную схемку - MX25L1605 опознаёт, читает, пишет, проверяет без проблем. Шьёт минуты три.
А 25Х80 Возьмет?
Injenercrb
14-11-2011 10:03
japan, подскажи а Windbond 25X80 сможет прошить?
japan
15-11-2011 18:05
прошьёт наверное
Dimm
19-11-2011 20:23
zeppelin писал:
Касательно двух типов :
Добавление :
по выводу 3 - WP# - врай-протект - надо поставить джампер или выключатель - которыми надо прижимать к +3 вольт вывод врайт- протект .
Почему ?
Потому что так пишет процедура в даташите .
Надо замкнуть WP# на + , и дать команду снять биты защиты .
Они (биты защиты) сразу инициализуются - при дачи команды /i - команда "инфо" .
Подскажите однако, прог не шьет 25VF080B, это особенность флешки или с программатором что то не так, и что куда прижимать
bsat
Гость 217.174.*.*
03-12-2011 09:09
Уважаемые господа, прошу помочь прошить 25016SCP. Собрал схему на резисторах и попробовал прогой SPI Flash Programmer v1.8 Rus.rar, а также SPI_TT_v1.035. Стирается и шъется но с ошибками.
Jenius
20-02-2012 23:24
Привет всем!
Собрал SPIFLASH
http://spiflash.org/block/1.html
Пробую прошить: 25q80scp все вроде работает но как-то странно!
Процесс чтения и прошивки длится больше 1часа! Считанный файл весит 16мгб! И идет многократный повтор блоков в считанном файле! Что делаю не так подскажите плизз!
Буфер использовал :SN74HC244N а по схеме должен стоять 74LS244. Может в этом проблема?
dmibr
22-02-2012 19:29
Эта память размером 1Мбайт=8Мбит, при считывании нужно в программе указать правильно размер. Или отрезать лишние повторяющиеся блоки в редакторе, например в WinHex.
Jenius
22-02-2012 22:26
dmibr писал:
Спасибо вроде разобрался, все именно так как Вы сказали, единственное какую микросхему я не выбираю ни чего не меняется, видимо программатор не знаком с данной ИМС. После ручной доработки все получилось! Большое спасибо!
tviker
27-02-2012 10:30
Кто подскажет а 25x32vs1g будет шить?
sh30fr
Гость 109.87.*.*
18-04-2012 16:50
Привет, всем!
Шил кто-нибудь микросхему 25Q64BV? Определяется, читается, анлочится, при записи пишется только первый бит, потом все FF.
Пробовал напряжения от 2.6 до 3.5. Прогер SPIPGM
Список форумов » Программное обеспечение » Тестируем програматор SPI FlashROM 25VF080 На страницу Пред.  1, 2, 3, 4  След.
Текущий раздел » Программное обеспечение (Вопросы и обсуждения программного обеспечения)
  • Кварцы...чем тестируем?
  • Тестируем открытые порта.
  • програматор JDM , проблема
  • програматор 93s56
  • Програматор Beeprog не работает
