SETool
Список форумов » Сотовые телефоны » Программаторы и софт На страницу Пред.  1, 2, 3  След.
Vad
Мобильщик
Мобильщик
19-09-2009 06:23
http://www.mobile-files.com/forum/showpost.php?p=593314&postcount= ...
v0.915050
- added alternative security bypass for semc a2 cid53 phones.
that allow you to repair completely dead a2 cid53 phones:
- destroyed trim area
- foreign gdfs
- damaged semcboot
please note, that alternative security bypass for a2 cid53
IS NOT free and NOT STANDALONE (check prices for details)
please note, that if you will execute alternative bypass mode for a2 cid53
in order to unlock/flash/etc - you will lose device key and
drm functions possible will be damaged.
usage of a2 cid53 alternative security bypass exactly same as for a2 cid49/52
and explained in details in FAQ.
- because several guys researched "mystery" of a2 .cxc and released
own tools, i forced to release ".vkp" patching support for a2 phones.
please note,that ".vkp" patching will only work on phones in r&d state.
please note,that ".vkp" patches and details will NOT be discussed in
setool2 section on mobile-files.com forum.
rapidshare FULL SETUP LINK
Vad
Мобильщик
Мобильщик
28-09-2009 11:09
http://www.mobile-files.com/forum/showpost.php?p=597742&postcount= ...
v0.915051
- added full support for upcoming semc db3350 phones.
as there are no phones on market, we can not test it,
so support for db3350 marked as HIGHLY EXPERIMENTAL.
flashing/gdfs/filesystem operations should work flawlessly.
full unlock via signature and "alternative bypass mode" SHOULD work too,
but that things are absolutely not tested, so
MAKE GDFS BACKUP before doing full unlock
and only touch alternative security bypass if you absolutely crazy
подмигивание
in any case, if phone will be killed - i will repair it for sure...
well, you have been warned.
please note, that alternative security bypass for a2 db3350 cid53
- in some VERY RARE cases lg db3200 phones became completely dead
after unlock attempt or unlock/flashing procedure failed in start.
that should be fixed now, at least i received many good reports.
Vad
Мобильщик
Мобильщик
07-10-2009 21:21
http://www.mobile-files.com/forum/showpost.php?p=603038&postcount= ...
v0.915052
- tested,fixed and apporved support for db3350 phones, thx to imobile
as my "dear friends" used to say: world first, genuine,blablabla,etc.
anyway, i'm sure everything works now for db3350 -
- full signature unlock
- altbypass mode
- flashing,filesystem,gdfs,trim area operations.
- regarding a2 cid53 phones:
use full signature unlock for FULLY GENUINE unlock.
it is fast and furious (tm)
use alternative bypass mode for completely damaged phones.
it is slower, but can fix any software problem.
in next 2-3 days i will release next version, which will not damage
device key in a2 cid53 phones when using alternative bypass mode.
(need to arrange reset station upgrade, that require some time)
in any way, i strongly recommend to use full signature unlock for
a1/a2 phones - it is absolutely genuine and can not tamper anything.
Vad
Мобильщик
Мобильщик
09-10-2009 05:27
http://www.mobile-files.com/forum/showpost.php?p=603772&postcount= ...
v0.915053
- a2 cid53 alternative bypass will not damage device key anymore.
because of that one more phone restart required, but who cares ?
- "unlock during flash" enabled for s1 phone patch unlock
- some not important fixups, thx to imobile for bugreports.
Vad
Мобильщик
Мобильщик
06-11-2009 15:22
http://www.mobile-files.com/forum/showpost.php?p=619755&postcount= ...
v0.915056
- added full support for s1_open PDA phones (satio).
big thanks to: cowboy, hardstone, shadowman,kris.sg for testing,
arash for logo.
notes:
in order to boot satio you MUST check "signed mode"
read flash requires "signed mode" and "alternative bypass" checked.
satio omap nand flash starts at 8000000
to execute network unlock/repair - check
both "signed mode" and "perform full unlock" then press unlock
to reset user code - check only signed mode and press unlock
if "unlock after flash" checked - user code will be reset after flashing.
to flash satio you must add zip package to firmware area.
do not unzip it !!!! just add.
Vad
Мобильщик
Мобильщик
02-12-2009 07:35
http://www.mobile-files.com/forum/showpost.php?p=633234&postcount= ...
v0.915057
- added support for repair dead db3200-based lg phones (gt505,etc)
procedure:
if /sys partition damaged
(you CAN'T read gdfs, eraseSecData errors)
add to firmware area gt505_syspart_fix.ssw
press flash
unlock phone
fullflash phone
if /drm partition damaged
(phone blinks on lg logo after /sys repair and you CAN read gdfs)
add to firmware area gt505_drm_fix.ssw
press flash
unlock phone
fullflash phone
- added support for repair semc a2 phones with flash cid>otp cid
procedure:
check "use signed mode",
"use alternative security bypass",
"use preloader security bypass"
press unlock
credits consumption same as a2 cid53 unlock feature.
Vad
Мобильщик
Мобильщик
10-02-2010 22:56
Заработал новый, официальный Форум поддержки SETool (на английском языке).
http://support.setool.net/forum.php
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=868& ...
v0.915058
- added support for repair erom on semc new security locosto,neptune phones.
procedure:
1. select correct model
2. on settings check "signed mode"
3. add erom to firmware tab.
if you have neptune based phone: 1207-7713_EROM_S1_NEPTUN_HS_SEMC_SIMLOCK_R7A024.sin
if you have locosto based phone, then select situable from:
J132_EROM_S1_LOCOSTO_HS_USB_R5A038_64k.sin
K330_T280_T270_EROM_S1_LOCOSTO_HS_R5A028.sin
R300_R306_T303_S1_LOCOSTO_HS_R5A031_128.SIN
T250_CXC1250616_EROM_S1_LOCOSTO_HS_R5A022.sin
Z250_Z320_EROM_S1_LOCOSTO_HS_R5A023.sin
4.press recovery
procedure require internet connection and paid: locosto based - 1 credit, neptune based - 2 credits.
- added support for high speed usb flashing. flashing speed of semc a2 phones will be twice as usual.
- some bugs fixed, one was very important
Download V0.915058
Vad
Мобильщик
Мобильщик
11-02-2010 22:09
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1001 ...
v0.915059
- broken db200x PDA support, fixed
- broken alternative bypass support, fixed
Download V0.915059
Vad
Мобильщик
Мобильщик
13-02-2010 15:02
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1203 ...
v0.915060
- broken calypso lite support, fixed
- further fixes for alternative bypass support
Download V0.915060
Если выскакивает окошко с проблемой файла ggsemcapi.dll , то смотрим решение по ссылке http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1221 ...
Vad
Мобильщик
Мобильщик
25-02-2010 07:05
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=2839 ...
v0.915061
- added support for S1 AID04 neptune-based phones.
there is no alternative security bypass for such phones, so only full network unlock supported.
- added support for A2 CID80.
- few bugfixes.
Download v0.915061
Vad
Мобильщик
Мобильщик
25-02-2010 18:36
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=2952 ...
v0.915062
- broken pnx5230 support,fixed
- solved "starting up..." hang issue when user installed usbflash drivers, but not connected any phone yet.
Download v0.915062
Vad
Мобильщик
Мобильщик
12-03-2010 21:28
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=4164 ...
from today, price for reset operation and alternative security bypass for db2001,db2012,db2020,db3150,db3200,db3210,db3350 phones are equal to zero.
For using this service - you must have valid SEtool account with above 1 credit.
standalone version can be released soon.
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=4398 ...
v1.0 FINAL
- added standalone support for reset operation, alternative security bypass for next chipsets:
supported s1 aid 0001,0002,0003.
supported a1/a2 cid 16,29,36,49,50,51,52,53,80
s1 omap
s1 locosto
s1 neptune
db 200x
db 201x
db 2020
db 3150
db 3200
db 3210
db 3350
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=4404 ...
SEtool PAID update.
Dear Setool Customers,
Please read carefully this major news announcement.
We (setool team) have proven that we are the best team in Sony Ericsson arena. We did many many updates for free and all years not asked for any additional payment. In last version we made may be the most HOT update from start. All function for s1 omap, s1 locosto, s1 neptun, db200x, db201x, db2020, db3150, db3200, db3210, db3350 are now working as a standalone. No internet connection or server required.
New time is coming, SEMC improve security and make new cid80 phones. We believe it is fair to ask customer a small payment to continue subscription for excellent setool support. This is necessary in order to invest in new test phones/handsets/sources/servers/staff etc to make all this support possible. Please be sure, we thought this hard and long time to make sure that it is fair and will not burden our loyal customer much.
Upgrade cost will be - 20 SEtool credits. Most of users have credits so can use it for license purchase. Users who have not valid account have to buy it from any autorised dealer listed here.
Upgrade procedure will include remote upgrade of card applet and card activation with license. It will allow you to work with sw versions greater than v1.0 and use new support site. Current file support will also work for current version users. Laser will come out with explanation of upgrade procedure in days ahead. We will try to make this upgrade as easy as possible.
Thank you for understanding and for your continuous support.
SEtool, ПЛАТНОЕ обновление.
Дорогие Клиенты Setool,
Пожалуйста прочитайте тщательно это главное объявление новостей.
Мы (команда setool) доказали, что мы - лучшая команда по продукту Sony Ericsson. Мы сделали много много обновлений бесплатно и за все годы, не попросили никакой дополнительной оплаты. В последней версии мы сделали, может быть САМОЕ ГОРЯЧЕЕ обновление с самого начала. Работа с s1 omap, s1 locosto, s1 neptun, db200x, db201x, db2020, db3150, db3200, db3210, db3350 теперь автономная. Никакое подключение к интернету или сервер не требуются.
Наступают новые времена, SEMC улучшают безопасность и делают новые телефоны cid80. Мы полагаем, что справедливо попросить, чтобы клиенты немного простимулировали поддержку продукта setool. Это необходимо, чтобы вложить капитал в новые испытательные телефоны/телефонные трубки/источники/серверы/штат и т.д, чтобы сделать всю эту поддержку возможной. ......
Стоимость модернизации будет - 20 кредитов SEtool. У большинства пользователей есть кредиты, их можно использовать это для покупки лицензии. Пользователи, у которых нет действительного счета, должны купить логи у диллеров.
Процедура модернизации будет включать отдаленную модернизацию апплета карты и активации карты с лицензией. Это позволит Вам работать с новыми версиями, выше v1.0 и использовать новый сайтк поддержки. ..... Лазер выпустит объяснение процедуры модернизации в ближайшие дни. Мы попытаемся сделать эту модернизацию настолько легкой насколько возможно.
Спасибо за понимание и за Вашу непрерывную поддержку.
Vad
Мобильщик
Мобильщик
16-03-2010 09:08
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=4828 ...
v1.01 FINAL
- fixed a2 cid80 support
Download v1.01 FINAL
Vad
Мобильщик
Мобильщик
12-04-2010 22:09
Обновление на версию 1.02 и выше платное. Стоимость - 20 логов.
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=6988 ...
v1.02
- added preliminary support for a2 cid26 phones (s5320 at the moment)
at the moment, network unlock possible by flashing special firmware from support
samsung s5320 should be connected with "9+#" pressed in order to enter boot mode.
all other functions supported without notable exceptions.
- added a2 db3150,db3200,db3210 emptyboard fill support.
you need special cable in order to successfully write OTP chip, +7.5v should be applied to DCIO (charger pin, pin 12)
Download v1.02
activation required in order to use that update.
just unpack 1.02.rar in existing setool2 directory
( setool2.ini not included in dist anymore, so your password/username will not be overwritten)
and run activator.exe.
i strongly advice users to run only activator.exe which included in v1.02 archive or from that LINK.
activation cost 20 credits.
activation will assure that you will be able to use latest setool2 updates and use new support area.
old support area will be frozen, no new flash files will be uploaded on it. also, old support area will be terminated in that year
thanks for your support.
Activator.zip 1.14 MB
- Добавлена предварительная поддержка телефонов Samsung платформы A2 CID26 (s5230 в данный момент).
Раскодировка от оператора пока возможна путём записи специальной прошивки с суппорта.
Samsung s5320 должен быть подключен по "9+#" в Boot режиме
все другие функции поддерживаются без исключений.
- Добавлена поддержка emptyboard fill для a2 db3150,db3200,db3210
Вам понадобится спец. кабель для записи OTP , *+7.5v* надо подать на DCIO (charger pin, pin 12)
* для пользования этой версией необходима активация.*
просто распакуйте версию 1.02 в существующую setool2 директорию (setool2.ini более не включается в дистрибутив программы, так что ваши password/username не будут перезаписаны).
затем запустите *activator.exe*.
строго пердупреждаю пользователей запускать только *activator.exe*. который включен в архив v1.02 или скачаный с этой ссылки: скачать *activator.exe*
активация стоит 20 SETool кредитов
активация гарантирует Вам, что у Вас будет возможность использовать последние обновления setool2 и использовать новую поддержку (Support).
Старый Support будет заморожен, и никакие новые флэш файлы не будут загружаться на неё.
Старый Support будет закрыт в этом году.
Добавлено 13 April 2010, 02:12
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=7135 ...
v1.03
- broken db2000,db2010 red cid49 support unsigned mode, fixed.
Rapidshare Link
Добавлено 13 April 2010, 02:13
warning:
please NOT try to flash samsung m5650 or any other emp-based samsung model with s5320 selected - you will damaged phone.
please wait for setool2 update, where that version will be listed in models.
Добавлено 13 April 2010, 02:14
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=9064 ...
v1.04
- added support for samsung m5650 phone.
it is absolutely necessary to select correct model, otherwise phone will be trashed.
always add main part of firmware first when flashing.
- added unlock codes calculation for samsung s5320,m5650 phones.
select correct model, check signed mode, press unlock.
it is absolutely necessary to select correct model, otherwise nothing good will be done.
thx to zoio,GeniuSShadoW for testing.
- a2 emptyboard fill procedure now works as intended
- fixed support for unlock a2 cid80 phones, when signature server offline
- fixed few minor bugs
- updated drivers
Rapidshare Link
v1.04
- Добавлена поддержка Samsung M5650
ВАЖНО правильно выбирать модель, иначе телефон будет повреждён.
Всегда выбирайте MAIN часть прошивки перед флэшированием
- Добавлена калькуляция кодов для Samsung M5650 и S5230.
Выберите правильную модель, отметьте signed mode, нажмите unlock.
ВАЖНО правильно выбирать модель, иначе ничего хорошего не произойдёт.
спасибо zoio,GeniuSShadoW за испытания.
- A2 emptyboard fill процедура тепеь работает как задумывалось
- Исправлена раскодировка телефонов A2 CID80, когда не работает сервер
- Некоторые незначительные исправления
- Обновлены драйвера
Vad
Мобильщик
Мобильщик
14-04-2010 06:01
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=9242 ...
v1.05
- some newer ODM firmwares were not parsed properly, fixed
- few cosmetic fixes
Rapidshare Link
- Исправлены некоторые FW ODM
- Несколько косметических исправлений
Vad
Мобильщик
Мобильщик
26-04-2010 17:26
http://www.mobile-files.ru/forum/showpost.php?p=1709773&postcount= ...
the_laser, сделал объявление о закрытии суппорта для "старых" (не активированных для версий v1.02 и выше) карт с 01 мая 2010 года.
От себя добавлю инфы:
У продавцов логов встречал в продаже по 30 логов, по цене от 75$ до 85$ (активация происходит за 20 логов + 10 остается).
Так же, есть "бюджетный вариант" обновления. Это покупается на троих (или на три карты) 60 логов вскладчину, а затем происходит поочередная активация карт (по одному логину/паролю). При таком варианте, очень важно соблюдать условие о правильности выставления даты на компьютерах во время активации (а лучше при этом делать по 1 активации с разрывом в 24 часа).
Vad
Мобильщик
Мобильщик
17-05-2010 19:00
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1219 ...
v1.06
- added support for qsd8250-based semc phones (x10 at the moment).
flashing,gesture lock reset,trim area read/write is standalone and free
please note, high quality usb cable required to work with x10.
network unlock is server-based and paid.
x10 network unlock disabled for public at the moment.
- added support for a2 cid81 phones.
flashing,user lock reset,gdfs area read/write is standalone and free
Rapidshare Link
- Добавлена поддержка телефонов на базе qsd8250 semc (на данный момент – x10).
Прошивка, сброс блокировки жестов, чтение/запись trim area делаются в режиме standalone и бесплатны, сетевая разблокировка производится сервером и за оплату.
Хотим также напомнить, что качественный кабель usb потребуется для операций с моделью x10.
Сетевая разблокировка x10 для общественности пока закрыта.
- Добавлена поддержка телефонов a2 cid81.
Прошивка, сброс кода пользователя, чтение/запись области gdfs делаются в режиме standalone и бесплатны, сетевая разблокировка производится сервером и за оплату.
- Несколько косметических изменений
Vad
Мобильщик
Мобильщик
18-05-2010 19:59
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1237 ...
v1.07
- fatal flashing bug fixed.
odm phones, pda phones was affected.
greatly sorry for inconveniences.
- memory consumption decreased while flashing x10 phones.
Rapidshare Link
- Исправлена ошибка при флэшировании ODM и PDA телефонов
Приносим извинения за неудобства.
- Уменьшена загрузка памяти PC при флэшировании Xperia X10
Vad
Мобильщик
Мобильщик
14-06-2010 20:05
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1501 ...
v1.08
- x10mini support added.
yes, network unlock still unavailable for public.
do not ask us for special x10-enabled accounts - they not exists.
- different bugfixes
Rapidshare Link
- Добавлена поддержка x10mini.
Сетевая разблокировка пока недоступна для широких масс.
И не спрашивайте о специальных аккаунтах для x10 – они не существуют.
- Небольшие исправления проблем.
Vad
Мобильщик
Мобильщик
23-06-2010 23:09
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1594 ...
v1.081
- increased server communication timeouts, can help in case of timeout errors
- different cosmetic bugfixes
Rapidshare Link
Обновлен SETool Box до версии 1.081. Внесены коммуникационные и косметические изменения.
- увеличены таймауты соединения с сервером, это может помочь в случае соответствующих ошибок
- различные косметические исправления
Vad
Мобильщик
Мобильщик
19-07-2010 06:50
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1819 ...
v1.084
- lg gt40x phones unlock/repair/flash functionality now works as intended, check FAQ for details
- no need to reflash after unlock some specific lg db3200-based phones from now on
- lg db3200-based phones now can utilize full USB2.0 speed
- further decreased memory usage during flashing of x1-alike phones
Rapidshare Link
- Разблокировка/восстановление/прошивка модели lg gt40x теперь работают, как полагается, смотрите FAQ
- Не нужно перешивать после разблокировки некоторые lg на базе db3200
- Все операции с телефонами lg на базе db3200 теперь производятся на полной скорости USB2.0
- уменьшено количество используемой памяти при прошивке x1-подобных телефонов
Vad
Мобильщик
Мобильщик
22-07-2010 05:36
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=1847 ...
v1.085
- updated a2 loaders
- updated s1 loaders
Rapidshare Link
- Обновлены загрузчики a2
- Обновлены загрузчики s1
- Разные косметические исправления
Vad
Мобильщик
Мобильщик
26-08-2010 04:58
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=2068 ...
v1.086
- added support for w100_spiro, network unlock is disabled at the moment
- updated model list
Rapidshare Link
- добавлена поддержка w100_spiro, раскодировка от оператора пока недоступна.
- обновлён список моделей.
- различные исправления.
Vad
Мобильщик
Мобильщик
31-08-2010 21:12
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=2118 ...
v1.087
- samsung m5650 support was broken from ~1.08x version, fixed.
Rapidshare Link
- начиная с версий ~1.08x были проблемы с поддержкой Samsung m5650, исправлено.
Vad
Мобильщик
Мобильщик
05-09-2010 08:14
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=2152 ...
v1.088
added unlock code request for w100 mobiles - and that is just start.
- we need special 12-digit serial number, NOT IMEI
- that special number can be readout during identify procedure for w100, starting from 1.088 version
- put 12-digit serial number in serial field on locks tab, press "request" button. if serial can be found, you will receive codes.
- cost of successful request - 1 credits.
fixed very rare "auth error" problem
few cosmetic fixes
Rapidshare Link
- Добавлен запрос кода разблокировки для w100.
Вам потребуется специальный 12-значный серийный номер, не IMEI. Этот специальный номер может быть вычитан во время процедуры identify для w100, начиная с версии SETool 1.088.
Впишите этот специальный 12-значный серийный номер в поле serial на вкладке locks, нажмите кнопку «request». Если номер будет найден, Вы получите коды разблокировки.
Стоимость одного удачного запроса кода – 1 кредит SETool.
- Исправлена достаточно редкая проблема «auth error».
- Некоторые косметические изменения.
Vad
Мобильщик
Мобильщик
10-09-2010 05:38
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=2188 ...
v1.089
- lg u8550 operations were broken from some version,fixed
Rapidshare Link
- Некорректно проходили операции с LG u8550 некоторых версий. Исправлено.
- Несколько косметических исправлений.
Vad
Мобильщик
Мобильщик
05-10-2010 19:09
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=2331 ...
v1.09
- w100 unlock by codes made simple - now you just need to check signed mode, altbypass and press unlock.
- few cosmetic fixes,few minor functionality improvements
Rapidshare Link
- Упрощена процедура разблокировки W100 – теперь Вам просто нужно проверить галочки на вкладке настроек (signed mode, altbypass) и нажать unlock.
- Некоторые исправления интерфейса, несколько небольших улучшений его функциональности.
Vad
Мобильщик
Мобильщик
20-12-2010 06:57
Цены
http://support.setool.net/showthread.php?16-CREDITS-CONSUMPTION
CREDITS CONSUMPTION
calypso lite/arima (ODM phones)
patch unlock is free
no unlock via server
locosto-based S1 phones (ODM phones)
patch unlock via server - 1 credit required
full unlock via server - 4 credits required (when signature server works) ( during promo )
neptune-based S1 phones (ODM phones)
STEricsson-based S1 phones (w100,w150...)
full unlock via server - x credits required ( unlock disabled for public )
full unlock via codes (please check if phone has unlock attempts remaining BEFORE requesting code) - 4 credits required ( during promo )
omap+db3210 based S1 phones (UIQ smartphones)
full unlock via server - 6 credits required ( aid 004 phones require s1 auth server to be online )
qualcomm-based S1 phones (ANDROID smartphones)
db2000 cid17/cid41/cid42/cid54 (lg3g)
db2000 cid24 (old sharp 3g)
full unlock is free
db2000 cid16
full unlock is free
full unlock via server - 1 credits
db2000/db2010 cid29
full unlock is free
db2000/db2010 cid36
full unlock is free
db2000/db2010 cid49
full unlock is free
reset mode (repair erom) - 1 credits
db2020 cid49
patch unlock standalone - free (required setool2 >=v0.914033)
Full unlock 6+0=6 credits required ( please use reset mode )
db2010 cid50
full unlock - 1 credits
db2010/db2020/pnx5230 cid51
reset mode (not applicate for pnx5230) (repair erom) - 1 credits
db2020 cid52
db2010/pnx5230 cid52
patch unlock is free (required setool2 >=v0.914029)
db2000 cid53
reset mode - 1 credits
db2010/db2020/pnx5230 cid53
db3150 (a2 platform) cid49,51,52
full standalone unlock is free
Full unlock 6+0=6 credits required ( please use unlock using altbypass )
db3150 (a2 platform) cid53
db3200 (a2 platform) cid49,51,52
db3200 (a2 platform) cid53
db3200 (a2 platform) cid80,cid81
db3210 (a2 platform) cid49,51,52
db3210 (a2 platform) cid53
db3210 (a2 platform) cid80,cid81
db3350 (a2 platform) cid53
db3350 (a2 platform) cid80,cid81
S1 (locosto,neptune) phones with aid 0001,0002,0003 patch unlock operation is standalone and free in current setool2 version
db2000,db2010,db2020 reset operation is standalone and free in current setool2 version
db3200,db3210,db3350 with CID 51,52,53 reset mode is standalone and free in current setool2 version
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=4885 ...
v1.10
- updated loaders for few phone models
- general bugfixes
- few minor interface improvements
Rapidshare Link
- обновлены загрузчики для нескольких новых моделей телефонов
- исправлены ошибки
- незначительные исправления пользовательского интерфейса
Vad
Мобильщик
Мобильщик
22-12-2010 07:01
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=4895 ...
for unknown reason ( cognac? ) a small typo was left in code, thus rendering message "phone not supported in that mode" during semc a2 unlock in altbypass mode.
that is pure cosmetic bug and can be ignored,
however, v1.10 was re-uploaded with that typo removed.
* В общем, скачайте по новой и переустановите эту версию.
Vad
Мобильщик
Мобильщик
05-01-2011 09:39
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=4964 ...
v1.101
- ancient bug (from very start of s1 patch unlock )with patch unlock of z250 was fixed.
- few minor internal changed
Rapidshare Link
- Исправлена давняя проблема разблокировки патчем модели z250.
- Обновлены загрузчики для некоторых моделей
- Несколько небольших внутренних изменений
Vad
Мобильщик
Мобильщик
06-01-2011 09:19
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=4973 ...
v1.102
- flashing of DB200x-based PDA was broken in v1.01, fixed
Rapidshare Link
- Исправление прошивки моделей PDA на базе DB200x, допущенной в версии 1.101
Vad
Мобильщик
Мобильщик
12-01-2011 10:50
http://support.setool.net/showthread.php?3-UPDATES-AND-NEWS&p=5020 ...
v1.103
- CCPU reset procedure could fail on some DB200X-based PDA phones, fixed.
- A2 loaders for SEMC phones updated to current versions
[url=Rapidshare Link]Rapidshare Link[/url]
- Исправлена процедура ССPU Reset на некоторых PDA-телефонах на базе DB200x
- Загрузчики для телефонов А2 SEMC обновлены на последнюю версию.
Список форумов » Сотовые телефоны » Программаторы и софт » SETool На страницу Пред.  1, 2, 3  След.
Текущий раздел » Сотовые телефоны » Программаторы и софт (Вопросы и обсуждения Программаторов и софта для ремонта связанного с ПО сотовых телефонов)
  • Setool и GDFS
  • Setool и J110
  • SeTool support
  • SEtool нет коннекта с телефоном
  • Setool 3 box не видит телефоны
