FAQ
(Service mode) .  1, 2, 3, 4, 5  .
busmaster
212.46.*.*
20-08-2006 18:12
TDA 88) o
custon-code. - 88
48, SAA3010, 455 432 -.datasheet.
(custom 00) ( LG,SHIVAKI 101 -), -
-: 05- "", 07-PHILIPS(TELRA),"","" .,
SITRONICS 2121(TDA9381PS/N2/3I-FM OSD-, TDA9381PS/N2/2I1091-CH05T0102)
- 37 , ( "") 37add51
- , 37add51 - . ,
( ) / 9012(KS5410) -(FUNAI,TMPA88),
KS5803 -(MIYOTA,SUPER),SC7461-(AVEST,AKIRA,ERISSON) . -
, 90% . (
"" -, TMPA8821CPNG4RJ1 (AKIRA, ERISSON,
SHIVAKI) FUNAI MK7 ( ). :
( - LCD) , -
IR- (
OMEGA-REMO ( - (,
) IR) !
popov
: 496
09-10-2006 10:35
SAMSUNG S51a
STAND-BY ---- DISPLAY --- MENU ---MUTE ---POWER ON
dvdok
: 18
09-10-2006 19:28
TV MT Logic CTVDVD215TX (BEKO Chassis K5). VCT 49X3F PZ F1 000
: MENU 9301
Miles
217.21.*.*
10-10-2006 15:37
Loewe Arcada 8672, 8772 .. Q2300, 2400
( , ) 4 " " Service, 1 .
194.158.*.*
11-10-2006 10:20
MIYOTA MY-6600R LCD miniTV 6''
2
Power--mute--call--timer--
- LCD miniTV SUPER 7" G700
AV-888
. S3F880AXZZ-AQBA
. TA1238ANG
13-10-2006 19:22
: Samsung TX-14N3DF (17)
: TDA 9361PS/N2/4/0717
EEPROM: 24C16
STAND-BY / DISPLAY/ MENU / MUTE / POWER-ON
VODOLIY
: 6
29-11-2006 06:38
MITSUBISHI TS-5053
29-11-2006 06:42
THOMSON servis mode
  mitsubishi.pdf  31,47   : 971 ()
  thomson_servicemode.pdf  53,52   : 1123 ()
: 41
29-12-2006 07:57
JVC-2134TEE
1. + .
2. DISPLEY PICTUPE MODE SERVISE MENU,
DISPLEY.
SERVISE MTNU
1.IF 2. V/C
3.DEF 4.VSM PRESET
5. PRESET
6. TURBO TIMER OFF/ON
MN1873287JE V2.00P
JVC CG ERCU V01
IF
1. VCO
2. DELAY POINT
VCO
^v <>
VCO(CW) 210.25 MHz
TOO HIGH
ABOVE REFERENCE
JST REFERENCE
BELOWO REFERENCE
TOO LOW
>AFT ADJVST -5C(00)
VCO ADJVST +04(20)
FINE , . .
DELAY POINT UHF
DELAY POINT 33
V/C
^v <>
1. CUTOFF (R)+127
(G)+127
(B)+127
2. DRIVE (R)+0
(B)+0
3. BRIGHT -127
4. CONT +0
5. COLOUR +0
6. TINT +63
7. SECAM BL ADJUST +0(4A)
8. SHARP +2
9. AMP T.SHARP +1
DEF -
^v <>
1. VER. POSITION +0
2. HOR. POSITION +0
3. VER. HIEIGHT -13
4. VER. LINE ARITY +12
5. VER. SCUARVE +0
6. HOR. VCO ADJUST +0
BRIGHT
^v <>
1. TINT 15
2. COLOUR 15
3. CONT 15
4. SHARP 15
PRESET
1. C-TR AP FIX 1
2. SHARP PEAK 1
3. ABL 1
4. CAMMA 1
5. Y. DELAY TIME 2
6. BLACK EXP START 2
7. C-BPF 1
8. CW/SCO 0
9. VIF DET LEVEL +10(24)
10. SIF DET LEVEL 0(08)
11. IF AGC MIN 0 1
12. VIF AGC 0
13. VIF PMOD 0
14. SIF BPF BW ADJUST +1(0E)
15. SIF TRAP FO ADJUST 0(9)
16. SIF TRAP FO ADJUST2 0(7)
17. SIF-TRAP 1
18. SIF-BPF 1
19. VNR 33
20. RGB LIM 1
21. RGB LIM LEVEL 3
22. SIF SW 1
23. TEXT H POSITION 1
24. REAF DATA
DATA 1 10000001
DATA 2 00100110
SISTEM CONSTANT SET 1
>CJLOUR :MULTI/TRIPLE/PAL
BILINGUAL :YES/NO
TUNER :MU/MA
ECO SENSOR :YES/NO
LANGUAGE :E/R/C/U
SISTEM CONSTANT SET 2
B/B COUND :ON/OFF
LOCK :YES/10/........../250
COLOUR AUTO :YES/AUTO
QSS :MQSS/MINT
ALC :YES/NO
SISTEM CONSTANT SET 3
AMP TUNER :YES/NO
VNR :YES/NO
TEXT TABLE :ARA/CYL
: 583
03-01-2007 01:03
" 55CTV733-22"
CTV733
1. XN102 .
2. :
"" , "SL", ". " , " "
- "+", "-" , "SL"
- "AV", "TV".
"": 1- , ""- , 25800. " " . .
84.18.*.*
05-02-2007 22:28
Pioneer PDP-503PE(HDE).
Enter, info, 0. .
Taras+
14-02-2007 16:06
GRUNDIG ELEGANCE 15 FLAT A36EKM74X31
TDA9345PS/N3/3/187/7
P1Y33 45
BEKO-ME164GRA06
SHASSI E1.
1.PICTURE MENU
2. " 8500"
: 265
20-02-2007 16:44
Schneider EURO 28FS -TV8 -70315 ( . . . . .+ --) - 1 (. ) , . , , .
meguel
: 4
21-02-2007 16:52
Loewe Xelos A20 , A37
"menu" , "-" , "service menu"
: 265
04-03-2007 17:07
SN ( ,) ( menu ,tv,i) VOL --,- . . Serv.2--option byte menu. . BIT IF ( DK bit 2) [/b]
Moriaan
: 1179
05-03-2007 21:05
TV ORION 346DC TV3350
"Menu" , . - "Power" .
kulibin-00
: 39
26-04-2007 17:43
Thomson 42WS90E (plazma)
vol+ vol-
tundra
: 28
31-05-2007 17:22
BEKO model 14272TDS , proc SDA5535 A071, service menu - 1.picture menu ,2. "9301",3.exit "0"
WaitMan
: 544
29-07-2007 15:34
: 11AK56
: TDA9550H/N3/3
<M> 4-7-2-5
073 - OFF ON
- <stand by>
DK
<M> <install>
<M> <7>
Yaric
: 128
14-08-2007 19:12
LG 21FC1RB 5-7 .
Kosarev
: 17
20-08-2007 12:10
, 12 " " , ,, ,
%D0%A1%D0%95%D0%A0%D0%92%D0%98%D0%A1%D0%9D%D0%AB%D0%95.%D0%A0%D0%95%D0%96%D0%98%D0%9C%D0%AB.%D0%A2%D0%92.1-12.rar
20-08-2007 12:12
[/url] СЕРВИСНЫЕ.РЕЖИМЫ.ТВ.1-12.rar (1,17 GB)[url][/url]
Desc
: 59
12-09-2007 09:32
Kosarev :
, 12 " " , ,, ,
20-08-2007 12:12
: 46
24-09-2007 08:27
http://varis-1959.narod.ru/Doc6.htm
arturkiti
: 312
02-10-2007 22:29
mladshi,
: 587
18-10-2007 19:05
LG CT-29k37 MC007 , LG. OK , . OK . 46 ( 100 . .)
II
: 6
25-10-2007 00:22
OPERA OP-V104
mute--call--timer--
- menu. -v.
: 1
27-10-2007 13:53
- , . , --VTX SYSTEM 14 , A WEISS EIN AUS, REFERENZ 0 63 , IIC BUS AUS. ? ?
zxbor1
: 263
02-11-2007 01:49
Funai LCD C2007 LCD C1504
, stb,2,7,1 mute 5 .
( Jovani).
http://monitor.net.ru/forum/funai-lcd-c1504-lcd-c2004-download-3106.ht ...
LCD A1506 LCD B1506 LCD C1506 LCD D1506
LCD A2006 LCD B2006 LCD C2006 LCD D2006
LCD A2007 LCD D2007
ava
: 1
15-11-2007 00:09
LG CT-29Q91RB
, 5-10.
bilykv
: 14
17-12-2007 18:22
samurai :
PFILIPS14PV425\07
Philips 14PV225/01
14PV425/07
Z12
2 :
. (PLAY) (STOP) 10 .
2
2-7-1-mute 5 . STATUS/EXIT,
PAUSE 5, . STANDBY
0179
http://www.tele-servis.ru/forum/viewtopic.php?p=3845&sid=fc15b3897 ...
andijan
: 5
20-12-2007 19:07
SUPRA STV2089W, -PTYM01
: KMP87P38N-1B09
SE135, A968A, STR F6654, TDA8842
serg128
30-12-2007 00:18
anger1
Avest, AKIRA 14FES1, SHIVAKI, TRONY 21TS89, Shivaki STV-2565,
PAEX0078A
1 .
: EASTKIT 8821CPNG4RJ1 , 24C16A, LA78040, D2498, D2499, LA4267.
2 .
:8821CPNG4RJ1 , STV9302A, D2492, C5586.
3 .
AKIRA 21FZP1
: 8821CPNG4RJ1 , STV9302A, D2492, C5586
(INSTALL) (4), (7), (2), (5). ADJUST ( ).
STV-1415
STV-2113MK2
4 . (VOL-) . (Prog), ( --), (TV). (PROGRAM UP) (PROGRAM DOWN), (VOL-), (VOL+). .
STV-1414/T, STV-2110
. (SVC).
STV-2905
(SERVICE) . 2). OSD ( ) "Line SVC". (-/--) .
STV-2119
(DISPLAY) (MUTE) (SLEEP) (FUZZY).
(DISPLAY) , SLEEP - .
STV-216 MULTI, STV-2129, CS-29A6HTR
(ST.BY) (MUTE) (MENU) (POWER ON)
CTV-2139
. AV ,
. AV TV .
: 250-500 ms 760.
. P+ P-, VOL+ VOL-.
. TV .
3
: 379
03-01-2008 22:57
LCD Cameron 3207. SERVICE: 1) VOL.- min. 2) IN STAND.BY.3) TV . PROG.+ and VOL.+ . POWER.
(Service mode) . , , . .  1, 2, 3, 4, 5  .
(Service mode) (C () )
  • PHILIPS 28PT447558-
  • UOC- TDA93xx
  • VIDEOCOLOR .
  • 16:9
  •     , , dvd, . Schematic, Service Manual (mode), eeprom dumps      - , , ,    ,  ,      , , datasheet, pdf,
