yuvitaliy Участник Сообщения: 198
Пришел в ремонт SIEMENS A75, включается на одну сек (загор. дисплей), затем отключается. Акамулятор в норме. Разрезал тестпоинт, взял joker, залил FF выдал:
FullFlash file info:
FlashID: 0001/220C
SIEMENS A75 Sw20 lg98
RealLgPack: lg91
Start...
Loading BootsModel(A75)...
Sending StartBoot Ok.
Sending MainBoot Ok.
Com6 460800 BAUD: Ok.
SIEMENS A75 lg98 Sw20
Soft FlashID: 0001/220C
FlashID: 0001/227E-220C-2201
Flash Size: 8Mb, WriteBuffer: 32 bytes
Region(1): Blocks 128, Size 64Kb
Start EEPROM segments at addres 0xFC0000
FSN: BBF3DCF3 -> PhoneID: F3DCF3BB
OTP IMEI: 356474003138515
HASH: ADE04C3802A02B67E4EEF77849CADA15
Read EEP0067 block (ver00), size 20 bytes - Ok.
Read EEP0076 block (ver00), size 10 bytes - Ok.
Read EEP5005 block (ver00), size 64 bytes - Ok.
Read EEP5007 block (ver00), size 10 bytes - Ok.
Read EEP5008 block (ver00), size 224 bytes - Ok.
Read EEP5009 block (ver00), size 10 bytes - Ok.
Read EEP5012 block (ver00), size 12 bytes - Ok.
Read EEP5077 block (ver00), size 232 bytes - Ok.
Read EEP5093 block (ver00), size 76 bytes - Ok.
Read EEP5121 block (ver00), size 56 bytes - Ok.
Read EEP5122 block (ver00), size 6 bytes - Ok.
Read EEP5123 block (ver00), size 12 bytes - Ok.
EEPROM blocks is written in ".\Backup\A75lg98Sw20_Backup061227224145.eep" file.
Restore EEP0067 - Ok.
Restore EEP5005 - Ok.
Restore EEP5007 - Ok.
Restore EEP5012 - Ok.
Restore EEP5093 - Ok.
Data file "D:\Documents and Settings\JokerV034\A75_80-80_FF.bin".
Write Flash addr: 0x800000 size: 0x800000 - Ok.
Вроде всё ОК. Затем вернулся SKEY (перещитать ключи), Use IMEI: воткнул родной, нажал на ReCalc All Keys, выдал:
Start...
Use EXT IMEI: 356474003138515
USE SKEY: 12345678
*#0000*12345678# - Network Lock
*#0001*12345678# - Service Provider Lock
*#0002*12345678# - Corporate Code
*#0003*12345678# - Phone Code
*#0004*12345678# - Network Subset Lock
*#0005*12345678# - Only Sim
Read BCORE addr: 0x800000 size: 0x010000...
Error Read Flash block 0x800000 size 0x004000!
Телефон ведет себя так-же как и раньше. Может что то не так делаю? Чем вызвана последняя строка, кто знает? (Error Read Flash block 0x800000 size 0x004000!) |
Vad Мобильщик  Сообщения: 4912
Во первых, если уверен, что не железо, посмотреть ошибку выхода никогда не бывает лишним.
Во вторых, может надо было только FFSInit пролить?
В третьих, скорость великовата. Лучше на 10 минут больше подождать, чем потом ломать голову - "почему не шьется?" |
Да уж как только не пробовал. Лил другой ФФ, ставил минимальный Бодрейт, всё на месте. Service mode проходит без проблем.
Start...
Loading ServiceBoot...
Sending ServiceBoot Ok.
BFB Speed 115200 Baud - Ok.
HWID: 237 (A75)
A75 lg98 Sw20 19.05.05 14:07:25
DisplayID: 46, Wintek STE2020
Code(05): OTP closed
Code(09): BootKEY is written in EEPROM
Code(0D): Keys are registered in BCORE
Code(10): Minimal access to BFB
Code(15): Complete condition
Code(19): Monitoring is switched on
Code(1D): Blocks 5121,5122,5123 are present
Battery Voltage 3785 mV.
SecurityMode: Customer
Что ещё ему вздрючить?! |
Bakser Участник Сообщения: 116
Зарядить аккум., сделать Joker'ом Del Instances - обычно этого хватает. Включить, когда тел протормозится - залить FFSInit. А начинать в этом случае с заливки FF не стоило. |
rommy Участник Сообщения: 3226
| yuvitaliy писал: | | Чем вызвана последняя строка, кто знает? (Error Read Flash block 0x800000 size 0x004000!) |
После прогрева их обычно попускает.
Перед тем проверить кабель-может обрыв в проводах,особенно в разъёме,обрываются провода после частого юзания.
Зарядить аккум. |
alexrai Участник Сообщения: 245
Я в таких случаях даже над ТП не напрягаюсь, заганяю в тест мод, Del Instance, и через пару минут (зависит от того насколько загружена была файловая система) тел готов к работе, но только пустой.
FF конечно зря сделал, да и скорость великовата.
Судя по логу прошивал джокером, а не установлена ли отметка защиты загрузчика?
Похоже при прошивке Bootcore не изменялся!
Использовать, я думаю, лучше OTP IMEI. Наши таланты могут этикетку от самолета на тел приклеить.
Прогрев врядли будет результативным, похоже глюк програмный. |
Загонял в SERV Mode, делал Del Instance. Тело включается, но без контента. При повторной попытке включ не происходит. Затем пробовал лить FFSinit, прога виснит с надписью Phone connecting - please wait!, так и висит. Пробовал SST 6.50. Вообще глушняк. Одним словом не знаю что и делать . |
| Цитата: | | При повторной попытке включ не происходит. |
Не понял!
После Del Instance один раз включается а потом опять труп?
Можно обойтись и без FFS, любой прогой для закачки контента в тел (в инете навалом). |
Сандро Мобильщик  Сообщения: 930
yuvitaliy, решение могу предложить нестандартное.Во всяком случае мне помогло.Мучался я мучался с Сименсом(с каким точно не помню,но EGOLD),тоже шил перешивал,кабели перебирал.Пытался Sinit в него впихнуть,но безрезультатно.Переустановил винду(полная переустановка)и все заработало.Попробуй,если есть желание .По моему мнению этот,гы,нехороший человек в очках и сам то толком не знает как эта ХР работает.Да ему и не нужно,он деньги зарабатывает.Готовимся принять еще один продукт от Майкрософт.Я про Висту...  |
yuvitaliy, был похожий случай с А75. После Del Instance, получилось залить FFSinit лишь с 4 или 5 попытки. То вообще не заводилась прога, то вставала посредине процесса. Потом кое-как пробило. |
Чо я только не делал, ни какого сдвига, всё одно и тоже! Может всё таки шнурок махнуть. Порты менял. Искал на СОМ1, ни где нет в продаже. Они хоть существуют? |
