Samsung SV0412H нипроходит тест
detale
02-03-2008 14:27
Попался в руки Самсунг SV0412H (SK 300-15) . Решил его сформотировать с Hutil от Samsung. Запустил тест и тест покозал "CHECK M.C. error DRQ timeout". Запустил SHDIAG показивает что хард хороший. Дайте совет где копать. Спосибо
neo831
02-03-2008 14:36
SMART покажи.
detale
02-03-2008 17:06
þ HDD 1 Model: SAMSUNG SV0412H
þ HDD 1 Size: 38204 Mb (37.31 Gb)
þ Location: Primary Master
þ Serial Number: 0536J1DW409378
þ Controller Revision: SK300-15
þ Buffer Size: 2048.0 kb
þ Compatibility: ATA/ATAPI-6 revision 28
þ PIO Mode Support: 4
þ SW DMA Mode Support: None
þ MW DMA Mode Support: 2, Active: None
þ UDMA Mode Support: 5 (UltraDMA/100), Active: 5
þ Current AAM Value: 00h (80h recommended) - disabled
þ S.M.A.R.T.: [û] enabled
þ SMART Self-test: [û] enabled
þ SMART Error Logging: [û] enabled
Attribute ID Threshold Value Indicator 1/Month T.E.C.
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
Raw Read Error Rate 1 0 100 þþþþþþþþþþ 0.0 Unknown
Start/Stop Count 4 0 97 þþþþþþþþþþ 0.0 Unknown
* Reallocated Sector Count 5 9 253 þþþþþþþþþþ 0.0 Unknown
* Seek Error Rate 7 51 253 þþþþþþþþþþ 0.0 Unknown
Seek Time Performance 8 0 253 þþþþþþþþþþ 0.0 Unknown
Power On Hours Count 9 0 99 þþþþþþþþþþ 0.0 Unknown
Drive Power Cycle Count 12 0 99 þþþþþþþþþþ 0.0 Unknown
Drive Temperature 194 0 1 0.0 Unknown
* Current Pending Sector 197 9 253 þþþþþþþþþþ 0.0 Unknown
* Uncorrectable Sector 198 9 253 þþþþþþþþþþ 0.0 Unknown
UltraDMA CRC Error Rate 199 0 100 þþþþþþþþþþ 0.0 Unknown
* Write Error Rate 200 51 100 þþþþþþþþþþ 0.0 Unknown
* TA Counter Detected 201 51 100 þþþþþþþþþþ 0.0 Unknown
NOTE: "*" means life-critical attribute
þ T.E.C. not detected.
Attribute ID Threshold Value Worst Raw Type
Raw Read Error Rate 1 0 100 100 0000000008EDh ER
Start/Stop Count 4 0 97 97 000000000D69h EC SP
* Reallocated Sector Count 5 9 253 253 000000000000h EC SP
* Seek Error Rate 7 51 253 253 000000000000h ER
Seek Time Performance 8 0 253 253 000000000000h PR SP
Power On Hours Count 9 0 99 99 0000000A4BBFh EC SP
Drive Power Cycle Count 12 0 99 99 0000000006CDh EC SP
Drive Temperature 194 0 1 0 0000000000E3h SP
* Current Pending Sector 197 9 253 253 000000000000h EC SP
* Uncorrectable Sector 198 9 253 253 000000000000h EC SP
UltraDMA CRC Error Rate 199 0 100 100 000000000000h ER
* Write Error Rate 200 51 100 100 000000000000h ER
* TA Counter Detected 201 51 100 100 000000000000h ER
Attribute types:
PR - Performance-related ER - Error rate
EC - Events count SP - Self-preserve
þ Reallocated Sectors: 0
þ Current Temperature: 227 C
þ Drive Power Cycle Count: 1741
detale
02-03-2008 18:08
И ещё, при старте головы стукает два раза
misha2
02-03-2008 19:10
Это Самсунг Верна , 2-х головый...может одной голове плохо... Надо бы по головам потестить . И глянуть бы сколько дефектов по каждой из голов. Но ни реалокейтов нету, ни кандидатов. шок Кстати , что говорит Хутил - не удивляйся...
detale
02-03-2008 19:35
А нормально что при старте головы два раза стучит? Я думаю что нинормально
misha2
02-03-2008 22:11
Ненормально. Я имею ввиду , что может голова себя плохо чувствует и не сразу прочитывает служебку с блинов. Поэтому и сказал , что неплохо бы посмотреть кол-во дефектов по головам. Если в норме, тогда может в служебке слетел какой-нибудь модуль. То есть нужно проанализировать что с винтом и в чём причина. У меня такой же лежит, одной голове совсем плохо стало. А 20-ку с него делать нерентабельно. улыбка
detale
02-03-2008 23:01
Спосибо misha2
Список форумов » Компьютерная и оргтехника » Samsung SV0412H нипроходит тест
  • Заводской тест на ST43313A
  • На мамке QDI не проходит 3D тест видяха!
  • Посоветуйте комплексный тест системного блока
  • Мать или видео? Тест и анализ неисправности.
  • ИБП Powercom KIN800AP не проходит тест батарей при включении
