Аппарат 2-ой зоны на сайте www.videohelp.com сказано следущее
To convert the Samsung DVD-V55K player to Multi-Region playback make
sure you have no disc or tape in and then Turn it on. When the display shows
"no disc"…...
1. Press the DVD button on your remote control so the Samsung DigitALL
logo appears on the screen
2. Press the SUBTITLE button on your remote control
3. Using your remote control enter the code: 5, 7, 5, 3, 8
Note: You should not see the numbers on screen as you type them
If you do Turn off and start again.
4. The current region should be displayed on the screen. (eg "05") If this
doesn't happen then turn off
and then on and try again
5. Press the 9 button on your remote control for Region free
6. Press the Open button on your player
7. Close Tray.
8. Power the unit off, then power the unit on again
Не помогло, может кто имел дело с таким аппаратом или есть прошивочка на 5-ую зону.
Текущий раздел »
DVD (Ремонт DVD плееров и домашних кинотеатров)
