Panasonic NV-VP31 (VHS+DVD) ошибка F09
Список форумов » DVD
qahri75
20-01-2008 13:39
Panasonic NV-VP31 (VHS+DVD) на табло FO9.
В механике VHS обнаружено монетки.
При включении (не нажимая on/off ) после 3-4 сек даёт ошибка FO9.
что за ошибка ?
comporator
20-01-2008 15:10
U11:Head Clog
U30:Remote Control Mode Error
H01:Cylinder Drive Problem
H02:Capstan Drive Problem
F03:Mech.Lock Problem during mode change
F04:Mech.Lock in Unloading condition
F05:Tape could not be rewound in unloading mode after Eject Button pressed
F06:Eject could not be made due to tape jam
F07:REC circuit defect during Recording mode
F08:REC circuit defect except Recording mode
F09:Between System Control IC and Timer IC DATA transmission error
Добавлено 20-01-2008 15:12
1). U10 Dew formation
Wait until the indication disappears.
2). H01 After cylinder lock is detected, the cylinder does not start rotating again even after tape unloading.
Check the cylinder-motor drive circuit.
3). H02 Cassette tape is not wound up during tape unloading except Eject mode.
Check the capstan-motor drive circuit.
4). F03 Mechanism locks during mode transition except Eject mode.
1. Check the loading-motor drive circuit.
2. Check the mechanism phase alignment.
3. Check the Mode Switch.
5). F04 Mechanism lock during tape unloading.
1. Check the loading-motor driveї circuit.
6). F05 Cassette tape is not wound up during tape unloading in Eject mode.
1. Check the capstan-motor drive circuit.
2. Check the Supply/Take-up reel pulse.
7). F06 Mechanism locks after tape unloading in Eject mode.
2. Check the mechanism phase alignment for Cassette Holder Unit.
8). F09 No serial clock transmission between IC6001 and IC7501.
Check the serial clock circuit.
Думаю хватит. голливудская улыбка
qahri75
20-01-2008 15:26
спасибо, проверью !
comporator
22-01-2008 08:42
Ну и чем дело закончилось?
zaslaw
27-01-2008 08:47
Сними кассетоприёмник выставь контрольные точки. вручную проверь работу ЛПМ .установи кассетоприемник .Должно все работать
Список форумов » DVD » Panasonic NV-VP31 (VHS+DVD) ошибка F09
  • Panasonic NV-VP31 no disk
  • Panasonic NV-VP31 заблокирована DVD секция.
  • Panasonic NV-VP31 CLOSE потом NO DISC
  • Panasonic NV-VP31 останавливает чтение диска
  • Panasonic SA-DM3 ошибка F61
