Canon i70 сброс памперса
Kreys
01-02-2007 15:45
Принтер Canon i70 - подскажите пожалуйста как сбросить памперс.
tokar
01-02-2007 16:07
Kreys, сам не проверял,
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME 2 times and release the POWER button.
5: When the indicator lights steady, press RESUME 3 times. The indicator should be orange.
6: Press Power to set data
Kreys
01-02-2007 16:10
Спасибо, попробую - напишу.
Kreys
01-02-2007 17:13
Не работает. Этот метод я видел на start-copy - там пишут что он для серии BJC. Для i70 ничего не смог пока найти рёв в три ручья
StalkerUa
01-02-2007 17:23
2-2. Adjustment / Repair
(1) Service mode
The basic operations are the same as those of the i70/PIXUS 50i. (Refer to the PIXUS 50i / i70
Service Manual.)
In this section, destination settings, which differs from those of the i70 / PIXUS 50i, are detailed
(difference in red).
<Service mode operation procedures>
1) Turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in either orange or green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of
time(s) according to the function listed in the table below. (Each time the Resume/Cancel
button is pressed, the LED lights alternately in either orange or green, starting with orange.)
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Both the main and borderless printing waste ink
counters are reset.
Kreys
02-02-2007 09:22
StalkerUa - СПАСИБО!!!!! То что надо! Всё работает! улыбка
Список форумов » Компьютерная и оргтехника » Canon i70 сброс памперса
  • Сброс памперса Canon Pixma IP 1500
  • Сброс памперса Epson STYLUS Photo RX690
  • Сброс счетчика СХ4300 (9 пиновый)
  • ПРОЭКТОР LG RD-JT50 сброс счетчика
  • Как в принтере - сканере HP Deskjet F380 сделать сброс?
