enderov, Для входа в сервисное меню надо быстро нажать комбинацию следующих кнопок: Меню048263*
На экране должно появиться приглашение для ввода команд: Opcode:___________
Дальше можно вводить команды, например 54*18*1 - полный сброс телефона. (54* - обязательное начало для всех команд)
Команды:
0*0*0 Select tone 0
0*0*1 Select tone 1
0*0*2 Select tone 2
0*0*3 Select tone 3
0*0*4 Select tone 4
0*0*5 Select tone 5
0*0*6 Select tone 6
0*0*7 Select tone 7
0*0*8 Select tone 8
0*0*9 Select tone 9
0*0*124 Select tone 1 KHz
0*0*125 Select tone 2 KHz
0*0*126 Select tone 3 KHz
0*0*127 Select tone 4 KHz
0*1*X Disable tone X
3*0*1 Enable vibrator
3*0*0 Disable vibrator
4*3*1 Enable speech coder full rate Audio loopback
4*3*0 Disable speech coder full rate
4*4*1 Enable speech coder enhanced full rate
36 January 23, 2003 6809456A82
Troubleshooting C350 Series
4*4*0 Disable speech coder enhanced full rate
4*5*1 Enable speech coder half rate
4*5*0 Disable speech coder half rate
5*0*0 Set audio level 0 Audio level
5*0*1 Set audio level 1
5*0*2 Set audio level 2
5*0*3 Set audio level 3
5*0*4 Set audio level 4
5*0*5 Set audio level 5
5*0*6 Set audio level 6
5*0*7 Set audio level 7
5*0*8 Set audio level 8
5*0*9 Set audio level 9
5*0*10 Set audio level 10
5*0*11 Set audio level 11
5*0*12 Set audio level 12
5*0*13 Set audio level 13
5*0*14 Set audio level 14
5*0*15 Set audio level 15
6*2*2*0*0 Set Audio Path. Int Mic, IntSpk, RX unmute, TX unmute
6*4*6*0*0 Set Audio Path. Boom Mic, Boom Spk, RX unmute, TX unmute
10*0*3 Set band GSM 900
10*0*4 Set band DCS 1800
10*0*5 Set band PCS 1900
10*0*6 Set dual band GSM 900 / 1800
10*1*0 Read band 3= GSM 4= DCS 5= PCS 6 =GSM/DCS
18*0 Initialize non-volatile memory (Master Reset)
18*1 Initialize Non-volatile memory (Master Clear)
20*X*0 Load Channel number X Select Channel (Used for debugging Rx mode)
20*1*0 Load channel number 1 GSM Low channel
20*62*0 Load channel number 62 GSM Mid channel
20*124*0 Load channel number 124 GSM High channel
20*512*0 Load channel number 512 DCS Low channel
20*700*0 Load channel number 700 DCS Mid channel
20*885*0 Load channel number 885 CDS High channel
20*512*0 Load channel number 512 PCS Low channel
20*661*0 Load channel number 661 PCS Mid channel
20*810*0 Load channel number 810 PCS High channel
55*2*001 Test Display. All pixels ON
55*2*000 Test Display. All pixels OFF
55*2*002 Test Display. Checkerboard pattern A
Table 2. Manual Test Commands (Continued)
Key Sequence Test Function/Name Remarks
Level 1 and 2 Service Manual Troubleshooting
55*2*003 Test Display. Checkerboard pattern B
55*2*004 Test Display. Border pixels ON
*#06# IMEI Check No Test Mode Required
НЕТМОНИТОР включается: Меню 00**83786633*
выключается: MENU 00**8378633*
нажимать надо очень быстро. выключаете трубку, и он появляется при каждом включении. Выйти в меню/обратно: меню-левая софт кнопка
