принесли это тело с диагнозом прога моргал и всё прошил жафом вот инфо
MCU ID: 0x2292
FLASH ID0: 327E0001 <=> SPANSION -> 71NS128P Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.30
31-03-08
RM-305
(c) NMP
HW version: 4500
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: P06w45.v50
LCD version: SDI:GUINv86
S6B33D1
PPM version: V 5.30
31-03-08
RM-305
(c) NMP
EL
ADSP SW version: V 5.30\n31-03-08\nRM-305\n(c) NMP\nel
Production serial number: FE0370870
Product code: 0566418
Module code: 0203271
Basic production code: 0565612
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 352918026083482
IMEI spare to net: 3A 25 19 08 62 80 43 08
IMEI SV to net: 33 25 19 08 62 80 43 58 F5
Master Code: 1360120217
Phone type: RM-305, Software version: 5.30, Language Pack: EL
User code: ÿ#
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-305.ini
Saved INI not found, loading INI list...
No ini files found...
Done!
вот лог если не ошибаюсь MCU SW version: V 5.30
31-03-08
RM-305
(c) NMP
HW version: 4500
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
S6B33D1
PPM version: V 5.30
31-03-08
RM-305
(c) NMP
EL
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
Phone Type:
MCU Flash file: F:\GSM\UFS6\net2000\Nokia\Phoenix\Nokia\Phoenix\Products\1650 RM-305\rm305_05.530
Phone Type:
PPM Flash file: F:\GSM\UFS6\net2000\Nokia\Phoenix\Nokia\Phoenix\Products\1650 RM-305\rm305_05.53el
Phone Type:
CNT Flash file: F:\GSM\UFS6\net2000\Nokia\Phoenix\Nokia\Phoenix\Products\1650 RM-305\rm3050_nai5.53el
MCU: F:\GSM\UFS6\net2000\Nokia\Phoenix\Nokia\Phoenix\Products\1650 RM-305\rm305_05.530
Booting phone...
MCU ID: 0x2292
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x7E320100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: 8b
Loader is ready...
MSID: 84AE35098894F044D5BF6076C1
MSID decoded: 3E4EBAE90093821FAA000000
FAID: 19D36C3D83746F8C7A7CF5F9
Operation took 0 minutes 11 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 01000000 - 0100FFFF...
Erasing area: 01010000 - 0179FFFF...
Erasing area: 017A0000 - 017EFFFF...
Erasing area: 01F00000 - 01FDFFFF...
Operation took 0 minutes 37 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 41 seconds...
Restarting MCU...
PPM: F:\GSM\UFS6\net2000\Nokia\Phoenix\Nokia\Phoenix\Products\1650 RM-305\rm305_05.53el
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 847E9DE4AFDF71920F20ACA9EA
MSID decoded: 3E4EBAE90093821FA9000000
FAID: 222038C9D4E42B157FD96FDB
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 01240000 - 0125FFFF...
Erasing area: 01260000 - 0175FFFF...
Operation took 0 minutes 23 seconds...
Writing...
Operation took 0 minutes 43 seconds...
Restarting MCU...
CNT: F:\GSM\UFS6\net2000\Nokia\Phoenix\Nokia\Phoenix\Products\1650 RM-305\rm3050_nai5.53el
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 849F62EF409495DFD8D99AC5D3
MSID decoded: 3E4EBAE90093821FA8000000
FAID: 32A87DC3C43A007D130D38C5
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01760000 - 0179FFFF...
Operation took 0 minutes 1 seconds...
Writing...
Operation took 0 minutes 4 seconds...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 3 minutes 7 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-305, Software version: 5.53
IMEI: 352918026083482
Product Code: 0566418
Resetting PPC...
Done!
прошилась так тел не включился сделал анлок тел вклычается но нету мелодий и при входе в мелодии тел перезагружается
