disonic Участник Сообщения: 100
пусть лежат в одном месте и пополняються
*#66*# Set Factory Mode CONFIRMED
*#8375# Show Software Version CONFIRMED
*#1234# A2DP ACP Mode CONFIRMED
*#1234# A2DP INT Mode CONFIRMED
*#0000# + Send : Set Default Language CONFIRMED
*#0007# + Send : Set Language to Russian CONFIRMED
*#0033# + Send : Set Language to French CONFIRMED
*#0034# + Send : Set Language to Spanish CONFIRMED
*#0039# + Send : Set Language to Italian CONFIRMED
*#0044# + Send : Set Language to English CONFIRMED
*#0049# + Send : Set Language to German CONFIRMED
*#0066# + Send : Set Language to Thai CONFIRMED
*#0084# + Send : Set Language to Vietnamese CONFIRMED
*#0966# + Send : Set Language to Arabic CONFIRMED
More some codes for reset mobile china
*#77218114#
*#881188#
*#94267357#
*#9426*357#
*#19912006#
*#118811#
*#3646633#
CHINESE MODELS:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
for n95 that trips off on making call use
*#3646633#
goto misc item 6,and goto amr and press center botton
*#2346# sw wer
*#*#2005#injener menyu
*#55*#-test i info
*77*66# Auto test
*#33778#serial numer
*#648# kontrast
*#6810# reset
*#0044#-en lng
*#0007#-ru lng
*#035670766*001# ctrl=0(незнаю для чего)
*#035670766*002#....Task dbg(незнаю для чего)
N73
*#864364# menu
*#864322# info
*#86428# test
*#864798#version info summary
*#86476#serial
*#864523# kontrast
*#86437447#reset
*#1234#.*#12345#
*#0044#-en lng
*#0007#-ru lng
Код сервиса на SAMSUNG D500i
________________________________________
*#3646633#
Пока для 8800
*#2346# sw wer
*#55*#-test i info
*77*66# Auto test
*#648# kontrast
*#6810# reset
*#0044#-en lng
*#0007#-ru lng
N73
*#864364# menu
*#864322# info
*#86428# test
*#86476#serial
*#864523# kontrast
*#86437447#reset
*#1234#.*#12345#
*#0044#-en lng
*#0007#-ru lng
*#3646633#:rules:
*23177726*#
*28760404*# |
jaxun Участник Сообщения: 367
disonic, спасибочки  |
Vad Мобильщик  Сообщения: 4911
Nokia N95 1sim.
Перегружался при звонке (в том числе и на 112).
*#3646633#
Выбираем 6 пункт - Misc (Разное)
Выбираем 10 пункт - AMR (включить)
Выходим из меню, выключаем телефон, передергиваем АКБ. |
Олег спец Участник Сообщения: 613
Service codes Samsung:
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes VK-Mobile 3xx, 5xx:
software version: *#79#
software version: *#837#
service menu: *#85*364# (hold #)
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG:
software version: 2945#*#
KG300 NVRAM format: 2945#*# -> menu 15
Service codes Sony-Ericsson:
J100 software version: #82#
Service codes Fly:
M100 software version: ####0000#
2040(i) reset defaults: *#987*99# Send
MX200 reset defaults: *#987*99# Send
MX200 software version: *#900# Send
SL300m reset defaults: *#987*99# Send
SL300m software version: *#900# Send
SL500m reset defaults: *#987*99# Send
SL500m software version: *#900# Send
MP500 reset defaults: *#987*99# Send
MP500 software version: *#900# Send
Set language to English: *#0044#
Set language to Russian: *#0007#
Service codes Konka:
C926 software version: *320# Send
C926 set default language: *#0000# Send
C926 set English language: *#0044# Send
Service codes GStar:
GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
Service codes Motorola:
Motofone F3 software version: **9999* Send
C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
C138, C139, C140 software version: #02#*
C155, C156, C157 software version: #02#*
C257, C261 software version: #02#*
V171, V172, V173 software version: #02#*
V175, V176, V176 software version: #02#*
C168, W220 software version: *#**837#
W208, W375 software version: #02#*
PS Очень помогло, когда на cect все сбросилось по умолчанию на китай, этим кодом без проблем переключился на русский *#0007#
инженерное меню *#0366633# новая верту |
alzibert Новичок Сообщения: 13
ВНИМАНИЕ!
При вводе этого кода *#6810# reset тел будет игнорировать ранее работавшие коды, заводской режим и инженерное меню будут недоступны.
Если уже доигрались, то пробуйте так:
меню>установки>восстановить заводские настройки; при запросе пароля по умолчанию 1122 или 3344, 1234, 5678.
полезный код *#8376# версия дисплея;
*#28526*# пароль отмены 000000.
Вообще-то коды для конкретного тела видны если открыть фулл в winhex.
Будьте отзывчивы! Поделитесь информацией по инженерному меню: настройка, опции... - полезно будет всем.
пытливый ум - требует жертв |
ZEN Участник Сообщения: 249
G-Star (сервис,инженер-меню): *#3646633#,*#*#2005#,*#66*#,*#528364#
*#1122#
*#1234#
*#*#2005#
*#864364#
*#3646633#
*23177726*#
*28760404*#
*#661*#
*#864364#
*#3338913#
для 8800
*#2346# sw wer
*#55*#-test i info
*77*66# Auto test
*#648# kontrast
*#6810# reset
*#0044#-en lng
*#0007#-ru lng
N73
*#864364# menu
*#864322# info
*#86428# test
*#86476#serial
*#864523# kontrast
*#86437447#reset
*#1234#.*#12345#
*#0044#-en lng
*#0007#-ru lng
Philips S800
*#0000# - язык по умолчанию
*#0044# - английский
*#8375# - версия ПО
*#3338913# - Engineer mode
*#13*# - Factory mode
*#87# - Auto test
*#3378# - серийный номер (не IMEI)
*#523# - контрастность
FLY
#*301#02# зел. трубка затем #*8000# и #*3676# (делать с сим- мозги двум Флаям 688 подправил.)
MX 200 *#987*99# full reset
NEC
Put a 2G Simcard and turn ON the phone.
#4960*60473590#
*4960*60473590*60473590#
Turn OFF and ON again.
Codes for imei 356790001777545, model Nec N343i
Unlocking codes:
Code for NCKKN is : **00012*09578188#
Code for NSCKN is : **00022*07356788#
Code for SPCKS is : **00032*09538988#
Code for CKCCK is : **00042*01316788#
Code for PCKKP is : **00052*09538188#
Code for XXXXX is : **00062*01310788#
Code for XXXXX is : **00072*07350788#
Repair codes:
Code for NCKKN2 is : **00013*61928397#
Code for NSCKN2 is : **00023*61300117#
Code for SPCKS2 is : **00033*61588357#
Code for CKCCK2 is : **00043*61300117#
Code for PCKKP2 is : **00053*61928337#
Code for XXXXX2 is : **00063*61100117#
Code for XXXXX2 is : **00073*61106117#
Bosch
*#3262255*8378# (*#DANCALL*TEST#) вход в инженерное меню
10. Engineering
10.1 MS Info
10.1.1 on
10.1.2 off
10.2 Software details
10.2.1 Software version
10.2.2 EEPROM version
10.2 Test / Production details
10.3.1 Hardware data
10.3.2 Production data
10.3.3 Service data
10.3.4 Mechanical data
*#0000# выбор языка по умолчанию (Reset to english)
#3370# сброс телефона
*#9000# ввод кода sim lock
*#9001# ввод кода corporate lock (Bosch 90
*#9002# ввод кода provider lock (Bosch 90
*#9003# ввод кода network lock
*#9100# удаление sim lock permanently
*#9101# удаление corporate lock permanently
*#9102# удаление provider lock permanently
*#9103# удаление network lock permanently
*#9104# удаление subset lock permanently
(SIM-lock не является SP-lock/Service Provider lock!!!)
Dr2005alex # 8 2008-05-01 00:00 GMT
10 сообщений
CHINESE MODELS:
Коды для P168 (клон IPhone)
COPY D820 SAMSUNG
*#19992006# ---->phone reset
COPY NOKIA 6280
*#9426*357#
Service codes BenQ:
Service codes LG:
Service codes Fly:
Service codes Motofone-F3:
***300* Set SIM Pin
***310* / ***311* SIM Pin ON | OFF
***000* Reset Factory settings
***644* Set Voicemail number
***260* / ***261* Auto keypad lock ON | OFF
***510* / ***511* Voice Prompts ON | OFF
***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
***200608* Send: software version
***200606* Send: software version
***200806* Send: flex version
***250* / ***251* Keypad tones ON | OFF
***470* Select time format
***500* /***501* Prepaid Balance Display ON | OFF
***520* Change language
ZTE Mobile:>
1- *938*737381#
2- PHONE WILL DIPLAYED DONE
3- POWER OFF YOUR PHONE AND POWER ON AGAIN
alcatel:>E205
unlocking phone code,only press***847# without simcard
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200 |
Текущий раздел »
Сотовые телефоны »
Китайские модели (Ремонт китайских сотовых телефонов - собственных брэндов и копий/подделок под известные брэнды)
